meth with a 2.79
Old Aug 16, 2008 | 11:03 AM
sscobalt21's Avatar
meth with a 2.79
if i have 42lb injectors and run meth and all cooling mods will it be ok
Old Aug 16, 2008 | 02:00 PM
brett5's Avatar
dude use the search....that will not have anything to do with you running a smaller pulley on 42 lb injectors.your injectors will get stuck open..you need 60's
Old Aug 16, 2008 | 02:03 PM
Greased's Avatar
its called going static not stuck open.
Old Aug 16, 2008 | 02:04 PM
brett5's Avatar
well i know what its called but thats what happens
Old Aug 16, 2008 | 04:35 PM
sscobalt21's Avatar
what about a 2.85 search sucks its a pain in the ass
Old Aug 16, 2008 | 04:38 PM
EatonTVS07's Avatar
go 60's anything below 2.9, some people will tune 2.8 on 42's but, to be safe go 60's, plus it leaves you room to play with if you want to go to a smaller pulley
light'bolt's Avatar
not without a tune
Old Aug 16, 2008 | 05:35 PM
brett5's Avatar
i agree i would play it safe my self after all it is my DD
Old Aug 17, 2008 | 04:10 PM
ShortStack's Avatar
i ahve 42s and 2.8, run fine, just dont do back to back to back pulls..
Honestly i would be more worried about heat soaking with the 2.8 than going over on your idcs... But since you have meth you would be fine..
BTW static is being stuck open, and being stuck open is static... so it doesnt really matter...
And also, i woudlnt go under a 2.8 due to inefficiency...
Last edited by ShortStack; Aug 17, 2008 at 04:10 PM. Reason: Automerged Doublepost
Old Aug 17, 2008 | 04:12 PM
BriantheLion26's Avatar
You can get away with 42s on water injection but that can be pushing it too depending how lean you tune it. I am on 42s and a 2.9" and I push close to 90% duty.
Don't run under a 2.9" on 42s. If you want the boost, get 60s and play it safe. You can make plenty of power with 42s on a 2.9" if you tune it right.
Old Aug 17, 2008 | 04:24 PM
EatonTVS07's Avatar
area47 says he can make more power out of the 3" or the 2.9" with 42's then the 42's and the 2.8 so i 'd say either 60's cooling mods and smaller pullies and a tune or a 2.9 and a tune
Old Aug 17, 2008 | 04:32 PM
I know personally on my car it will never see a 2.8" without 60s. IDCs are just too high. You get 60s and will be set for just about any pulley you want.
Old Aug 17, 2008 | 04:35 PM
EatonTVS07's Avatar
i hear that the guy that had my car before me had it tuned for 2.8 on 42's and idc's where like 93%
Old Aug 17, 2008 | 04:37 PM
burntorange's Avatar
My 2.79 has been on for almost a year and a half now, and the car has been ridden like a two dollar ***** everyday and my IDC's are only in the 90's without meth and with meth they are in the 70's
Old Aug 17, 2008 | 04:40 PM
Unless you are running ungodly lean I don't even see how that is possible. Post up a log of yours sometime Id like to look at it.
Old Aug 17, 2008 | 04:45 PM
Correction, 86 totally sorry guys, looked at the wrong thing. I got too excited. I will send you one of my logs.
Old Aug 17, 2008 | 04:47 PM
CBodnar's Avatar
i run 2.8 pulley and have been for 23k + miles. trust me i drive it very hard and also now have 45wet shot.
still on gm stage 2 tune.
everyone says it is bad, but to this day i have yet to see a cobalt blow up off only gm stage 2 tune + 2.8 pulley. i am sure you will be fine.
also my buddy in his cobalt has 30k + miles on 2.8 pulley. just little reassurance for you.
good luck with whatever choice you pick.
Old Aug 17, 2008 | 04:58 PM
ralliartist's Avatar
well, if search sucks and it is a pain in the ass, then you just gave me perfect reason to be an *******. This topic has been covered many many times. We don't need newbs whoring up the forums with repeated threads. SEARCH, or get lost.
Old Aug 17, 2008 | 05:01 PM
Ouch
Old Aug 17, 2008 | 05:51 PM
BlackSSnTN's Avatar
my car is running 42's and a 2.8 right now, and you really cant get the power the car has to offer and stay at a safe idc. At least not from my point of view. I'm just taking it easy on the car until I can afford to do a swap, but i'm gonna go to a 2.7, Meth, H/E, Dual pass, and 60's, and buy a header to complete my exhaust, and get rid of the AEM cold air and get a full intake.
Old Aug 17, 2008 | 06:06 PM
8.1 degrees of knock for the win!!!! hahahahahahaahahahahaha
Old Aug 18, 2008 | 10:27 AM
ShortStack's Avatar
Sometimes though, if a topic has been covered too long ago, you can no longer search for it. Why does it matter anyway? If it gets you that pissed just dont answer his questions... in my opinion it would have taken longer to write that response than to just go look at another thread and not bother with it.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
