View Poll Results: Meth/HE or Dual Pass w/option B + HE?
Meth + HE
17
77.27%
Dual Pass w/ Option B + HE
22.73%
Voters: 22. You may not vote on this poll
Meth/HE? or Dual Pass/Option B/HE
Ok guys I cant decide what I want to do to cool this thing down a bit. I installed Intense Stage 3 about 3 weeks ago and my next mod will be cooling. Yea I know I should have done the cooling mods first
Should I go with a Cobra HE and Meth injection or a Dual pass with option B and a HE?
Also how much will it cost for Meth injection? And how tough is the install?
mods in my sig
mods in my sig
I have a new intake tubing coming to redo the nozzle point after some test I'll let you all know my findings!
I guess i can't vote here, And i will let you make your own decision on what you want. If you got any specific questions about methanol injection let me know. There is is much misconceptions and bad info out there its some times best to get your info from the horses mount. Snow is a good choice they do like use nickelplated fittings and there pump is methanol compatible. Some of the other companys out there parts arebrass and not compatible with methanol and there pumps have viton parts which will not last with methanol.
I will tell you how good the service was. I was installing this on the weekend so I guess the guy there wasn,t working so he gave me his cell number so I could contact him at his house if I had problems.(which I did cause me reading instruction=fail.
It does cause 1.It cools better than the heat exchanger and the dual pass combined. 2.It bumps you're octane up way higher than anything else you are going to by over the counter.
I counted that as the install. And yes the stock hoses are not the easiest to get to with a pair of pliers and don't even try to slide the clamps of the hose cause they are glued to the hoses with some mean mean mean ****.
z28addiction
Sep 28, 2015 12:03 AM
