Meth Help
Old Jul 10, 2008 | 09:38 PM
brownbandit9's Avatar
Meth Help
im still trying to get my ais kit in and i cant figure out how to run power from the fuze box to the wire...can someone please explain how to connect the wire to the fuse box so the pump only gets power when the car is on.....
also im not sure wich line is the boost line that i tap into...can someone post pictures of the boost line that will tell the pump when to spray..........thanks
Old Jul 10, 2008 | 09:39 PM
Altiery54's Avatar
the boost line is the 1 that runs on like top of the intake manifold and by the injector harness and then plugs in the back of a little rectangle looking thing.
Old Jul 10, 2008 | 09:46 PM
ohh is there also a line that runs from that rectangular thing to the inlet part of the actual supercharger itself.........
Old Jul 10, 2008 | 09:49 PM
MAJIN's Avatar
There are a few How To's in the How to section on this!
Old Jul 10, 2008 | 09:53 PM
Altiery54's Avatar
this might help
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/meth-install-help-119675/
Old Jul 10, 2008 | 11:52 PM
theneelster's Avatar
Ignition wire, radio wire...OR
(the poor man's automotive wiring experience) Wire it to the battery, wire a switch between and voila.
Old Jul 11, 2008 | 12:19 AM
everyone uses those add a fuse and plug right into the fuze box but u cant get one larger than 10amp and i need atleast 15 amp so that wont work..does anyone know what else i can do to wire this is...
any info would help alot...i have no idea how to wire this up so its only on when the car is runnin....
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
