meth injection
Old Apr 4, 2010 | 10:45 PM
DEZZIE41's Avatar
meth injection
looking at all possible info on meth injection im looking to get it the only thing my car has on it is a cai and high gloe converter with muffler....looking at diffuculty on intall, price, and i tun it on stock tune ETC thanks
Old Apr 5, 2010 | 09:13 AM
DEZZIE41's Avatar
bumpp
bump anyone
Old Apr 5, 2010 | 09:19 AM
JPizzle's Avatar
AIS, makes a kit, Devil's Own makes a kit, Snow Performance makes a kit.
I don't believe it's extremely difficult to install. Maybe a 5 or 6 out of 10... I believe the Devil's Own kit is about $265. And you can't really tune for it on the stock tune. You could go with a custom tune.
Old Apr 5, 2010 | 09:20 AM
DEZZIE41's Avatar
so no point to get it with out a tune
harryresh's Avatar
i wouldn't bother spending the money on it unless your pushing more than 17lbs of boost in my opinion
Old Apr 5, 2010 | 09:21 AM
DEZZIE41's Avatar
i got 15 stock
Old Apr 5, 2010 | 10:28 AM
Snakes709's Avatar
get smaller pulley and bigger injectors before you get meth....pointless getting meth right now
Old Apr 5, 2010 | 01:42 PM
venum_us_2002's Avatar
2.8 60s meth full exhaust custom tune
Good start
Old Apr 6, 2010 | 12:05 AM
InfraRedline's Avatar
Put your stage 2 on that you have sitting there first. Then if you want a custom tune get the meth and have someone tune you. And you should NOT be seeing 15 psi stock. Your cat may be clogged or your aftermarket muffler may be doing more bad than good by restricting airflow. I barely see 15psi on a 2.7 with full exhaust
Old Apr 6, 2010 | 12:13 AM
SS_T-Roy's Avatar
personally i would go with AIS, but you would want to do a little more to your ss first to really see the results you can get from getting meth injection along with a good tune and some more mods
Old Apr 6, 2010 | 12:28 AM
scotch89's Avatar
so i have a question on meth lol. in my signature you will see everything i have. when i was doing some pulls i noticed it wasnt getting the amount of horse power. i now this cause a kid with a stage 1 pulled on me in 3rd. so i think im "heat soaking" will this do the trick, or am i going to need something to add more coolant? like a HE and a dual pass?
Old Apr 6, 2010 | 01:23 AM
Snakes709's Avatar
if you are heat soaking...meth is your best option. Dual pass and a heat exchanger will help but meth will help even more then both of those combined.
Old Apr 6, 2010 | 11:55 AM
bj's05balt's Avatar
Get 60lbs injectors,your running your 42s really hard and are being restricted.
Old Apr 6, 2010 | 01:55 PM
TheSandMan's Avatar
Im also looking into getting meth for the dyno day at big shot on the 15th of may. I was wondering if you guys think i should stay with a 2.8 or should i go smaller?
Old Apr 6, 2010 | 02:08 PM
I would get a header before dropping pulley sizes. It will relieve some pressure and you will notice a nice gain. Then add meth and then after that if you want more then maybe drop to a 2.7
Old Apr 6, 2010 | 02:24 PM
TheSandMan's Avatar
Really, i didnt know a header for our cars made that much of a difference. So i would see more of a gain from the header over the meth?
Old Apr 6, 2010 | 02:27 PM
Snakes709's Avatar
I agree. I had a 2.8/60/meth and a few other parts set up. Then put the TVS, tuned that and was probably sitting around 260~ Bought header,dp and exhaust and it opend up alot more...made 280 with a safe tune.
Old Apr 6, 2010 | 02:34 PM
TheSandMan's Avatar
Im already over 260 as is. Actually i was at 260 before the hahn.
sorry about the thread jack here is a lot of good information. https://www.cobaltss.net/forums/alcohol-injection-systems-154/questions-about-water-methanol-alcohol-injection-post-them-here-83289/
Old Apr 11, 2010 | 05:39 PM
DEZZIE41's Avatar
is it worth it to run meth on stock tune
Old Apr 11, 2010 | 06:12 PM
No it will make you slower due to it being richer
Old Apr 11, 2010 | 06:13 PM
DEZZIE41's Avatar
damm
Old Apr 11, 2010 | 11:26 PM
skatin_boarding's Avatar
Get some nitrous if you want a bolt on horsepower solution.
Old Apr 11, 2010 | 11:40 PM
Snakes709's Avatar
he wants hp that he doesnt have to tune.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
