Meth injection
Old Nov 29, 2010 | 10:41 AM
joe_589's Avatar
Meth injection
Hi, I have been doing some research on this.
However I have not found out time frame on how long a 50/50 water/meth concetration of say 1L will last... Does anyone know?
Many thanks
Old Nov 29, 2010 | 12:47 PM
mrbelvedere's Avatar
it depends on your right foot
Old Nov 29, 2010 | 12:54 PM
joe_589's Avatar
Does it run all the time? I have seen a kit that only fires when full throttle or are they all the same?
Old Nov 29, 2010 | 01:03 PM
coopercharge's Avatar
they generally have a vacuum line attached to a sensor that turns the meth on so it depends on how much you go into boost so i.e. your right foot.
Old Nov 29, 2010 | 01:33 PM
CobaltSC06's Avatar
Like he said, it taps into your vacuum line and turns on at whatever the pump is set at, usually a turn of an Allen key will turn the boost up or down. If you get the progressive meth kit, it comes with a controller that you can set yourself from the inside of the car
Old Nov 29, 2010 | 01:35 PM
BYT*SS*TURBO's Avatar
Most people Ive had come with the 1Gal Tank seems to last about a month with normal driving. That first month will prolly be twice in the month since it's new and well...you want to have fun with it
Old Nov 29, 2010 | 02:00 PM
iboost's Avatar
like everyone says...depends on that right foot. If you mash the **** outa the pedal, you'll use meth. If you cruise you should be good. Mine kicks on at 8psi and is at full blast at 15psi
Old Nov 29, 2010 | 02:17 PM
joe_589's Avatar
What's a good kit that you lot use
I will have a custom tank made, probably around a gallon
Old Nov 29, 2010 | 02:21 PM
iboost's Avatar
There are a bunch out there...I use AEM's. There is also Devil's Own
Old Nov 29, 2010 | 02:22 PM
Why would you make a custom tank that is the size of the standard tank?
Old Nov 29, 2010 | 02:24 PM
iboost's Avatar
i wish I had a bigger tank that a 1 galllon...oh well
Old Nov 29, 2010 | 02:28 PM
joe_589's Avatar
I will be using a custom tank, as I don't have much room in my engine bay, also don't want the tank goin in the boot I don't own a cobalt just run the lsj engine
Old Nov 29, 2010 | 02:31 PM
iboost's Avatar
You can always put it in the trunk...
Old Nov 29, 2010 | 02:45 PM
Bluelightning's Avatar
Got Bewst?
I just tapped into my windshield washer tank. Holds lots
Old Nov 29, 2010 | 06:06 PM
joe_589's Avatar
It's fine I can sort a custom tank out
Will show some pictures when it's all done
Is there a place where i can buy a kit which includes all the parts apart from a tank?
Many thanks
Old Nov 29, 2010 | 06:10 PM
Chevycobaltss3's Avatar
Just have. Dworf underneath the hood while ure driving so when u give it throttle u can tell him to start pissing inside the intake ... ha ha ha ha ha.... but get the aem kit most coMplete I think.
Old Nov 29, 2010 | 09:00 PM
iboost's Avatar
Many thanks
Devils Own I think sells all the parts for a kit
Old Nov 29, 2010 | 09:02 PM
Bl4des's Avatar
has everything you need besides a tank
DVC-30 Meth Kit - Over The Top Performance
Old Nov 29, 2010 | 09:07 PM
Gunney_07's Avatar
Put in the trunk, its realy easy to set it up since the battery is already there!
Old Nov 29, 2010 | 10:45 PM
Got Bewst?
What happens if you need you're spare tire?
Old Nov 29, 2010 | 11:00 PM
carstedt's Avatar
my tank is in the back sittin up next to the corner out of the way and my pump is in my engine bay...then again i have a differnt kit than you guys i run the lebante stage 4 water/meth
Old Nov 29, 2010 | 11:46 PM
SunburstSS's Avatar
I use my washer fluid tank for meth , i dont like anything in my trunk " thats what she said lol ", i installed the pump right underneath my option b tank and it looks so clean over there, everything is hidden !
Old Nov 30, 2010 | 08:16 AM
joe_589's Avatar
i cant add the supercharger to intake spacer plate to add meth in there due to the supercharger will then hit my bulkhead in my car
i will probably use the TB spacer to run the meth injection there
all i would need is my custom tank, pipe, connectors for the tb spacer plate and a pump
hmmm
Old Nov 30, 2010 | 08:26 AM
Gunney_07's Avatar
you still can pull up the carpet the way i have it set.... but i dont have a spare only a tire inflator kit and aaa.
Old Nov 30, 2010 | 09:04 AM
SunburstSS's Avatar
hmmm
If you decide to tap into the intake tube i have the devils own meth tap that goes in there that i have no use for anymore
