Meth injection
Old Nov 30, 2010 | 12:02 PM
Bl4des's Avatar
Originally Posted by carstedt
my tank is in the back sittin up next to the corner out of the way and my pump is in my engine bay...then again i have a differnt kit than you guys i run the lebante stage 4 water/meth
you should not have you pump so far away they are made to push not suck fluid the pump needs to be a close to the tank as possible
Old Nov 30, 2010 | 04:25 PM
joe_589's Avatar
Thinking about it and talking to my mate I think I am going to drill 4 holes in the intake with direct feeds to each port so each port gets an equal amount of meth/water
So all I should need is:
Pump
4 x fittings
Custom tank
Some hose
Will upload pictures when done will see where the cheapest place to get then from
Does anyone know of just a pump for sale that just works on full throttle
I will search on devilsown.com when I get home from work they probably have the bits that I want!
Old Nov 30, 2010 | 10:28 PM
carstedt's Avatar
with the length of hose and wire..its more or less made to have it mounted in the trunk and the pump up front..but like i said thats a differnt kit than everyone else uses
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
