Meth Injection!
Old May 24, 2012 | 12:57 PM
sujomatt's Avatar
I was planning pre blower - i know i wont be using it all the time, id have to think its OK. its not 100% meth
Old May 24, 2012 | 11:52 PM
LaserblueSS's Avatar
that's what my theory was as well. its not like im constantly on the gas pedal and at 9psi or more.
Old May 25, 2012 | 12:08 AM
Bluelightning's Avatar
Got Bewst?
I sprayed preblower for 2 years with my M62 and the rotors were mint when I swapped to my TVS. Much more benificial spraying preblower also.
Old May 25, 2012 | 12:30 AM
dumpleRL's Avatar
Could you explain to me the difference between pre and after blower
Old May 25, 2012 | 07:34 AM
pre-blower is sprayed before the throttle body usually, by either tapping into the intake tube, or using a throttle body spacer that has a "port" for the meth nozzle to screw into. spraying pre-blower allows for the meth/water to cool down the supercharger itself, and the incoming air that is being shoved into the engine by the supercharger rotors.
post blower is usually done by having a plate underneath the supercharger, and the meth / water is sprayed into the intake. this also cools down the charged air, but does not cool down the blower at all.
Old May 25, 2012 | 09:10 AM
Got Bewst?
Another plus to preblower is it tightens up rotor tolerances creating more boost
Old May 25, 2012 | 01:02 PM
ive sprayed pre blower for 2.5 years, and probably 60k miles.
you can see where the line comes in before the throttle body coupler
and heres my rotors at 85k miles
Old May 31, 2012 | 01:05 AM
advise's Avatar
have a trunk mount ais stage 1 for sale
pm me for details
Old May 31, 2012 | 01:15 AM
mrbelvedere's Avatar
pm me for details
there is power to be had with water meth on e
Old May 31, 2012 | 01:24 AM
advise's Avatar
i used a 3gph nozzle with just water for cooling and had about a 5* difference
pointless lol
Old May 31, 2012 | 01:27 AM
  #36
run the 7 with a 50/50 mix to keep the blower cool
Old May 31, 2012 | 01:29 AM
  #37
advise's Avatar
then that would throw off my afr's too rich
may try the 7 with just water
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
