meth injection is just washer fluid??
Old Dec 11, 2008 | 12:49 AM
EXsoccer1921's Avatar
someone please explain this to me
Old Dec 11, 2008 | 12:52 AM
lsjwannabe's Avatar
Most -20 washer fluids contain 30% methanol in them.
Old Dec 11, 2008 | 12:55 AM
so how would someone get a higher mix?
Old Dec 11, 2008 | 12:57 AM
lsjwannabe's Avatar
Add a 10oz bottle of heet. When you treat that with one gallon of washerfluid it brings the mix up 10% approx, or you could get some 50/50 premixed like the devils own brew
Dead Zen's Avatar
Heet fueline freeze up stuff
Old Dec 11, 2008 | 12:59 AM
lsjwannabe's Avatar
http://www.goldeagle.com/heet/index.htm
yellow bottle
hmmm, i see. i was thinking about getting a trunk mount kit come spring time. just seeing whats out there and how i can get the most out of it
Old Dec 11, 2008 | 10:11 AM
ShortStack's Avatar
Type meth injection in the search alot comes up.
Old Dec 11, 2008 | 10:15 AM
roadrage06's Avatar
i've heard of people noticing stuff getting gummed up when they use washer fluid with repeated use. I'd stick with pure meth and eliminate the risk.
Old Dec 11, 2008 | 10:18 AM
ShortStack's Avatar
Thats because they used the wrong fluid..
I think its the purple stuff that has the gunk..
I believe its the red or blue with the least amount.
Old Dec 11, 2008 | 10:28 AM
lsjwannabe's Avatar
-20 is perfectly fine i ran it for over a year with heet. Just turns the intake mani and blower a nice blue color underneath.
exsoccer, let me know when your ready or shoot me a pm with questions and i can help you out.
Old Dec 11, 2008 | 10:43 AM
PhantomSS's Avatar
i dont use washer fluid because
1: i only see +20 stuff around
2: it will turn my engine's internals in to a smurf-like explosion.
Old Dec 11, 2008 | 11:17 AM
mcphatty's Avatar
that is completely wrong.
the reason people see build up is because they're using a cheaper brand of washer fluid. the company might be buying powdered dye that isn't totally dissolved by the time you buy the container. the gunk is undissolved particles. not using distilled water can affect this too, but color has absolutely nothing to do with it
all washer fluid is made up of is water, methanol, and dye.
johnladow07's Avatar
i smurf my supercharger...lol
Old Dec 11, 2008 | 11:39 AM
ShortStack's Avatar
Actually, it is not completely wrong..
If you look, the orange bottle has the bug cleaner in it, which the other ones do not
Different colors sometimes = different ingredients.
Old Dec 11, 2008 | 11:45 AM
PhantomSS's Avatar
qft
red stuff uses glycol or some other garbage.
yellow ammonia additives iirc.
blue is the only safe stuff i read on, the cheaper stuff was also better since they didnt use additives.
Old Dec 11, 2008 | 12:01 PM
maybe i'll just run 100% meth, 100% of the time hahaha
Old Dec 11, 2008 | 12:02 PM
lsjwannabe's Avatar
That can get a little pricey
Old Dec 11, 2008 | 12:03 PM
like how pricey?? lol
Old Dec 11, 2008 | 12:04 PM
PhantomSS's Avatar
Considering methanol is almost as expensive as denatured alcohol.
I know heet sells their bottles at 1.75
1.75x8=14.00 however they arent selling like a race shop.
15.00 gallon from home depot i get the Denatured Alcohol from.
Old Dec 11, 2008 | 12:08 PM
wait so youre saying you use denatured alcohol??? or am i just reading that wrong. that doesn't seem like a good idea to me
Old Dec 11, 2008 | 12:12 PM
ShortStack's Avatar
Methanol is just alcohol, as well.
Old Dec 11, 2008 | 12:14 PM
PhantomSS's Avatar
Denatured alcohol = ethanol+methanol (not e85)
methanol = methanol
denatured alcohol has a 130 octane rating
methanol has a 123(iirc) rating
so why not dump moonshine in the tank and call it good?
Old Dec 11, 2008 | 12:15 PM
PhantomSS's Avatar
they arent pure, plus id hate to have sugar gumming up my valves (if it had additives)
btw the only reason ethanol is undrinkable is because humans purposely put an additive in it to make it undrinkable.
