meth injection is just washer fluid??
so go to lowes, and buy this??
http://image.misterart.com/grouppix/...1000/g1542.jpg
cause i already have tons of it
Apparently you beat the **** out of the car. My car might see boost once or twice a week, and it sprays full bore at 5 psi. You do the math, it will last me a year.
The washer fluid tank holds 1.5 gal'ish. At 3 gph you can go 30 minutes wide open (or above 5 psi in my case). That is a long ass time.
Last edited by BriantheLion26; Dec 11, 2008 at 12:25 PM. Reason: Automerged Doublepost
Only way i could stay out of boost is to limit my tps to 25%
I like gas mileage.
*sigh*
Hmmm... so an 80% meth washer fluid concentrate WOULD be an ideal source, contrary to what I thought when I got the idea in my head. I also didn't want to smurf the engine!
Didn't think about clogged injectors tho!
if that is 100% denatured alcohol with no additives, then that is what people are using.
personally, i will never put windshield washer fluid in my engine. i've seen how chalky it gets on the outside of the wiper fluid resivoir when i spill some and dont wipe it up. no way do i want that in my engine.
going there now...
going there now...
going there now...
going there now...
btw heet is 10% methanol, 90% ethanol....
basicly denatured alcohol.
If you go to home depot you can get either
Methanol (shellac thinner)
Ethanol (Denatured Alcohol)
calculator says i need a 3.9 gph nozzle. Do they even make 4 gph nozzles? all i see is 3 and 5.
i thought the yellow bottles were 100% methanol and the red bottles were like 30%...
alright so as long as i make sure it doesn't have any additives i can use the crown denatured alcohol 100%??
hell you can run everclear if you REALLY wanted.
lol agree
