Meth Injection Kit
meth allows for cooler intake temps which create more power, higher octane which helps reduce knock and helps you tune more aggressively to make more power.
there aren't any real disadvantages.
click on the link in my sig for more cooling mods questions.
The only disadvantage would be to run out of the water/meth while you were driving hard. If you are running an aggressive tune with water/meth and then run out you may pop something. Or atleast damage something that will end up costing you money later. You would just have to check and see how much your using and top it off every now and then.
