meth injection problem
Alright I hookede up my AIS meth injection kit and now it runs as soon as you hook up the power. What did I do, you should have to blow in the vac line right. All i did was hook up the power and ground and pump continuosly runs.
What type of relay is it? Does it have one extra wire? That one wire on my old kit always had power. Did you accidentally hook that up? Check the pressure switch, get a small flat head and push it up, if you hear a click that means its getting engaged and it more than likely is not that. Check the wiring.
Alright tied hooking up again tonight I have a good ground to the back wire comin out the bottom of assembly. I hooked up power of pump to very top tab of vac switch. Then If I hook up battery power to middle tab Pump constantly pumps, and if I hook up to very bottom tab pump won't run believe me I blew on the vac line til I was about to pop a blood vessel or something. WTF what am I doing wrong this kit is SUPOSE to be easy plug and play basically.
Good LUCK you will feel it kick in if it does
