meth injection problem
Old 05-14-2009, 08:43 PM
BlueBolt66's Avatar
Alright I hookede up my AIS meth injection kit and now it runs as soon as you hook up the power. What did I do, you should have to blow in the vac line right. All i did was hook up the power and ground and pump continuosly runs.
Old 05-14-2009, 10:35 PM
Maxim_X's Avatar
You hooked up the wrong tab. There on 2 on the high side. Plug it into the other one.
Old 05-15-2009, 06:50 PM
KillinKrullin's Avatar
all you hooked up was power and ground? without that boost sensor in it might send a signal for full boost.... idk it could be either way.
Old 05-15-2009, 09:09 PM
SCcobaltSS's Avatar
What type of relay is it? Does it have one extra wire? That one wire on my old kit always had power. Did you accidentally hook that up? Check the pressure switch, get a small flat head and push it up, if you hear a click that means its getting engaged and it more than likely is not that. Check the wiring.
Old 05-21-2009, 09:46 PM
BlueBolt66's Avatar
Alright tied hooking up again tonight I have a good ground to the back wire comin out the bottom of assembly. I hooked up power of pump to very top tab of vac switch. Then If I hook up battery power to middle tab Pump constantly pumps, and if I hook up to very bottom tab pump won't run believe me I blew on the vac line til I was about to pop a blood vessel or something. WTF what am I doing wrong this kit is SUPOSE to be easy plug and play basically.
Old 05-21-2009, 10:17 PM
ShortStack's Avatar
What do you have the psi switch set to?
Old 05-21-2009, 10:32 PM
BlueBolt66's Avatar
that's the top hex correct? I don't really know I tryed loosening some and do it and no luck tightened it some still no luck.
Old 05-22-2009, 12:04 AM
SSLOW06's Avatar
It is ez plug and play hook the power wire up to the second connection wich is the one thatyou thought wassnt giving you any juice. I was blowing into the tube aswell and my ears almost popped i gave up hooked everything up and filled it up to the top i noticed it was working when the level of the fluid was going down slowly. So yes it does kick in an supposedly its set to 10lbs of boost . Try it and see fill it up and mark it lightly and drive hard for a little bit then go back and check it .
Good LUCK you will feel it kick in if it does
Old 05-22-2009, 12:18 AM
BlueBolt66's Avatar
alright cool will do thanks
Old 05-22-2009, 03:19 AM
Hockeyman's Avatar
bottom power connector, not the top one. The top one will make it on all the time.
01-12-2016 12:01 AM
yellow dragon
09-28-2015 09:49 PM
goaliemo
09-28-2015 01:37 PM
SlowSaturn
09-28-2015 11:03 AM
09-27-2015 08:53 PM
Quick Reply: meth injection problem
