Meth into Intake Manifold?
Which fuse or where could I hook up a 12v switched power cable (yellow cable from AEM meth controller) and also since solenoid if close to the fusebox on the engine bay, where could I hook that also to which fuse constantly is running 12v? or I just plug it the remote battery positive side?
I follow up the instructions and I hook up my coolingmist meth solenoid to the boost-safe wire, which is a 1.7amp switched ground, but I just got an email from coolingmist saying that its solenoid id 0.7amp for ground. So, I don't know if this amps have to match exactly or what, but solenoid is not opening with this setup. And when I hook it to the ground bolt in the engine bay, solenoid opens but get extremely hot, its fully open all the time...
about amps if you push to much amps into a product that requires less you will have issues, getting hot, blowing fuses, burning wires, ect. so if the solenoid is a wrong solenoid DO NOT USE IT>k..
what if tap it to the boost safe wire and also to the ground bolt on the engine bay? will that work?
What should I do? I just can't not use a $us 50 solenoid. Just bought it... ;/
Only way u csn wire it is the sig wire from the controller to the solonoid. u can't ground the solonoid to the chassis only to the sig wire for the controller. When the controller sees the amount of boodt rrquested to kick meth in it'll ground urr sig wire which is led to thr solenoids ground wire so no u can't ground both.
Just put the nozzle here. I think its a bit away from the TB, like 10". That won't be a problem?
I was wondering what if I put two nozzle because my kit came with two and I was thinking putting one of 5 and the other one of 8 gph. Would I get more hp? boost?
not really trhe place for it but if any of you guys still plan going direct port i have a ais stage 2 progressive kit with 4 nozzles and a 90 degree so you can make a direct port system and stainless lines directly cut for the cobalt. let me know if anyones interested. im going to explore secondary fueling in the lnf i dont need this. kits brand new never installed
