meth kit hook up
Old Aug 8, 2008 | 04:03 PM
brett5's Avatar
meth kit hook up
ok i have my cooling mist engine bay setup all hooked up and the windsheild washer tank tapped and ready but where do i hook the red wire on the pump to...? should i run it all the way beck to the trunk or should i run it to a fuse and if so which one....this is a non progressive and has no relay setup...and the inrtructions don't really specify
Old Aug 8, 2008 | 05:24 PM
theneelster's Avatar
Red, I'd assume is a power source. But if it's not progressive you're going to need to wire in an inline switch to trigger the meth I would suppose. There's a lot of different power sources you can tap.
Old Aug 8, 2008 | 09:49 PM
brett5's Avatar
in the fuse box in the engine bay.which fuse would i need to tap, the winshield wipers??? its a 25
i believe
and do our cars need a tee everyone on there how to/s have one but so i assume i need one and why can't we just use that open port underneath
Old Aug 8, 2008 | 11:45 PM
i believe
What do the instructions say? I wouldn't tap the engine fuse box, but the driver's one should be fine. Is it a 12volt pump?
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
OrangeCoba
Oct 1, 2015 10:00 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
