Meth nozzle help
Old May 27, 2009 | 07:11 PM
hatrickstu's Avatar
Meth nozzle help
i have a k&n intake. the nozzle is now falling out of the tube because its a thin soft aluminum tube. anyone weld a bung on one of these yet?
Old May 27, 2009 | 07:12 PM
Rodimus_Prime's Avatar
why not use one of the spacer plates that go after the throttle body, makes for easy the nozzle just screws right in
Old May 27, 2009 | 07:14 PM
Darkmanx's Avatar
im guessing he doesnt want to spend 100+ plus dollars on that but thats just me.
Old May 27, 2009 | 07:17 PM
1badBlueberrySC's Avatar
Stu I had the same one... I just used clear flowable silicone on the inside (if you can reach it on mine I could) and on the outside to seal it up!
Old May 27, 2009 | 07:22 PM
hatrickstu's Avatar
i like the idea, but not the idea of the silicone becoming dislodged and flying into my blower lol
Old May 27, 2009 | 07:25 PM
on my cavalier I used Orings on either side of the pipe from a fuel injector and a screw type injector from coolingmist, it was on a charge pipe and sealed well enough there wasnt any boost loss
Old May 27, 2009 | 07:27 PM
Stu... like I said I used mine for 20+k miles never once had an issue took it out several times for cleaning... if you are worried about that then just silicone the outside nothing to fly into blowa
Old May 27, 2009 | 07:33 PM
hatrickstu's Avatar
doing it the last way you suggested mohammad. thanks man
nicksredline's Avatar
yeah if u weld on a bung and then u can skrew and unskrew at any time without worry... we did this on my Grand national... It was easy once welded but i hate tiggin on thin metal like that so be warry... Or get a pro to do it.
Old May 27, 2009 | 07:35 PM
no problem man
Old May 27, 2009 | 07:37 PM
hatrickstu's Avatar
oh trust me, i will be nowhere near the welding equipment. the silicone will be the temporary solution and i will be ordering a bung online.
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
