meth problem!
Old Oct 2, 2008 | 09:27 PM
restonSS's Avatar
meth problem!
ok, so i think everything is wired correctly but my ais meth kit isnt turning on. could someone explain to me a vacuum line to hook it up to. pictures would be great. the pump doesnt turn on at all though, should it if it isnt hitting boost? im confused. thanks.
Old Oct 2, 2008 | 10:20 PM
WickedSS2005's Avatar
Check the boost actuater thing (I don't know the technical name). It's the small Allen key screw by the black box at the top of the pump. Adjust it CAREFULLY and see if it'll turn on. I had a similar problem tuning 95cam86roc's AIS meth kit when we installed it. It wasn't properly set to where Rodney said it should be from factory specs.
Old Oct 3, 2008 | 11:41 AM
restonSS's Avatar
ok thanks. just fyi, im using the vacuum line from the supercharger bpv. is that ok? its the black circle on the supercharger, im using the line that runs from that to the little black box 10 inches from it.
Old Oct 3, 2008 | 06:32 PM
restonSS's Avatar
ok, well i played with the allen key switch and still nothing. any other ideas guys?
Old Oct 3, 2008 | 07:13 PM
johnladow07's Avatar
Just give rodney a call, he is so patient and has really helped me out! 1 801 447 2559
Old Oct 3, 2008 | 07:16 PM
an0malous's Avatar
^^ agreed.
i had a few things not correct doing mine too, rod will walk you through it
Old Oct 3, 2008 | 07:27 PM
ColeJJones's Avatar
Bannned
I have pics of two installs I did... search threas started by me with the word meth.
im on my cell phone. can someone copy and paste the 2 links
Old Oct 3, 2008 | 09:42 PM
Try2k's Avatar
Make sure you have the vacuum hose that runs to the intake manifold. This was my problem. On one of the how-to's on here the pictures are wrong, but later are corrected on the next few pages. Double check that first
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
