Miles + Stg tune = Trouble?
got 60k on my car haven't had any stage upgrades looking to go to a 2.9 or 2.8 on stock s/c as well as hub.smaller,belt,60# injectors,QTP exhaust cut out, Cobra H/E and LS4 Throttle bod, and a m62 spacer?
how reliable would my car be?
very problem is putting up a few stages would i wear that engine fast to where the car won't last?
like i don't wanna blow up the head gasket and **** like that
You should be OK if you go with the GM Stage kit. You could replace the Head Gasket anyway, just to be safe. 60,000 miles isn't that much on an ecotec IMO.
Idk much about the stage kits though, so you may want another opinion
i want atleast 15-17 lbs of boost out of my stock s/c is this possible w/o blowing up the s/c or motor or am just being unrealistic?
i generally want 250-260hp outta my stock Cobalt w/o any gay issues
I don't have 3k to spend on a twin charged kit or i would also not really got much cash for clutch upgrade so i kinda have some limits
stage 2 with intake and exhaust and some traction mods will get you in your 250-260hp range
i put gm stage 2 on at 35k..have 60k now and its all good. You may need to replace the super charger coupler sooner (its cheap) but other then that you should be fine.
Also traction mods do not = whp...
SSchargedSS if you're making 250whp with stage 2 you better post a dyno sheet, because no one believes you.
"What are you gonna run on hopes and dreams?"
The SC was made to produce up to 245hp under warranty, but I'm guessing your 05 with 60k is now out of the warranty period.
So as long as you've taken care of your car (remember, regarding things mechanical "time does NOT heal all wounds") then I'd say go for it.
I just want to make sure know one believes this statement. Don't get the wrong idea. Stage 2 is good, but you will not be in the 250-260hp range. I had stage 2, exhaust, intake and I had more like 230whp. Which is about right. So don't expect to have 250whp with just that.
on a dynojet i put down 224.9hp and 192.5tq
stock pulley no stage kit
just some food for thought ahaha thats a funny saying
http://www.youtube.com/watch?v=apuJChYB6wQ
i mean i thought this was realisitic numbers I think it really depends on dyno
Hey Joemaster you are going down the right path. Your best option for the car is going to be the following. 60lb injectors, 2.8 pulley and hub, methanol injection, cxracing heat exchanger, interceptor to monitor things, wideband to monitor afr, and a tune from me. Your in chicago so thats not to far away at all. The tune is key man, if you get a tune from me you will have a very solid, very reliable, very powerful car. I can guarantee you the power you want with those mods. Easy 260whp, I could push it to 270 no problem also.
Also, this will not wear the engine down any faster. These ecotecs last a long time man, you can beat the **** out of them and as long as they are properly setup and tuned they will last. If you want to know my rates etc, pm me.
Last edited by Zach06CobaltSC; 09-13-2009 at 01:05 AM. Reason: Automerged Doublepost
The gm stage 2 tunes run extremely rich and don't run enough timing. If you increase the timing and lean them out a decent amount of power can be had, especially once you straighten out the torque reductions / boost reductions and all that stuff. But as far as the motor suffering and all of that, any additional stress or strain on a motor will wear it out quicker, however I have and know others who have ran extremely small pulleys, with proper cooling mods, for over 50k miles and have no issues. It really is all in the tune and how hard you beat on it.
If you don't need to, don't beat the **** outta the car and do back to back to back pulls. Those are the hardest on the car, the iat2's just get way to far outta hand.
I have a 2004 redline with 136,+++ miles. It has been staged since it had about 50,000 miles. My mods are K&N cold air intake, 2.85 pullie, 7200 rpm, sms big bore, 42lb injectors, stage 2 belt, 1 step colder plugs, lightning heat exchange custom tune (Thanks Fullthrottle) and a thermal muffler. And the only problem I have had is taking the smile of my face. These LSJ engines are very well built. Just do the regular maintance like change the oil every 3000 miles and you shoul be fine. I am on my 3rd stock clutch. First one lasted 50,000 miles second one lasted 70,000 then went out. Had the oringinal throw out bearing (got 120,000 miles out of it). Mind you I have not had any slippage since the new clutch, presure plate, flywheel and throwout bearing have been installed. Love your car like when you first bought it. Respect it by maintaing it. Admire it for how long it will last. This is what has worked with me and my 2004 redline. I took delivery of the car on 10/31/2004. The car had 3 miles on it.
