motor problem
Old Mar 5, 2011 | 09:52 PM
plaxton's Avatar
motor problem
i noticed that tonight when i was out running my car that when the rpm's get up to 6500-7000 my RPM's flutter a little bit. just wondering if anyone else had this happen. or am i just being paranoid.
Old Mar 6, 2011 | 01:07 AM
mrbelvedere's Avatar
check and see what ur afr is
Old Mar 6, 2011 | 02:15 AM
plaxton's Avatar
i'm kinda dumb on this one. how do i check this without a gauge? i only have a boost one setup
Old Mar 6, 2011 | 02:19 AM
D_sean257's Avatar
my car does the same thing but only in 3rd and 4th gear, second is fine. Idk what it is.
Old Mar 6, 2011 | 02:26 AM
plaxton's Avatar
i wasn't sure if it was suppose to do it. long time since i wound out the car like that. i was trying to push it a little blow out some of the carbon that builds up over time.
Old Mar 6, 2011 | 10:21 AM
JHans5774's Avatar
It's probably crank case pressure that's about when it will cause it to flutter -10an fitting on the valve cover to a -10an on the intake
Old Mar 6, 2011 | 10:31 AM
no dude excessive ccp will pop a dipstick or make it leak around a seal or gasket not flutter at high rpm / you need to get a wideban afr such as an aem and hook it up and see whats going on with ur afr
Old Mar 6, 2011 | 11:00 AM
xnigelx's Avatar
you should get a tune. you have aftermarket mods that you should get tuned for. and buy a damn wideband
Old Mar 6, 2011 | 11:15 PM
plaxton's Avatar
i don't have any real mods. there barely even considered bolt on's
Old Mar 7, 2011 | 01:07 AM
JHans5774's Avatar
That can happen but i have been told by several reputable people (Area, Elite Cyborg) that having to much crank case pressure causes rpms to flutter around 6800rpms
Old Mar 7, 2011 | 03:25 AM
AjSS's Avatar
You guys know what else can cause it to flutter? Too large of a spark plug gap, you may be blowing out the spark up high. Check your plugs, tighten the gap a little and see if it still happens. Sometimes people overlook the simple things...
Old Mar 7, 2011 | 04:07 PM
plaxton's Avatar
i will certainly take a look at this. if it helps. i am running the E3 style plugs
Old Mar 7, 2011 | 04:11 PM
GM COBALT SC SS's Avatar
i have heard nothing but bad things about e3s. especially on cobalts
Old Mar 7, 2011 | 04:32 PM
ngk stock#4644 gap around .032
Old Mar 7, 2011 | 05:23 PM
rukkee's Avatar
good call on the spark blow out idea ..... My old SS/SC was finichy about gaps and would do what the OP described in the higher rpm range if the gap was higher than .035 .
I would definitely get rid of those E3 plugs and go back to NGK's ... I remember a few people had problems with that style plug.
Old Mar 7, 2011 | 05:29 PM
06SS ALL DAY's Avatar
misfire
Old Mar 7, 2011 | 10:43 PM
plaxton's Avatar
sounds good. they will be taken out this weekend then.
Solaris99
28
Mar 15, 2017 01:22 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
