Mounts when buying ZZP downpipe
Old Jan 24, 2011 | 06:07 PM
sjc0013's Avatar
Window Licker
Just curious, how many people running a zzp downpipe actually use a solid motor mount/ trans mount, or both? I know zzp requires 1 or more if using their dp. I had planned on getting a solid engine mount regardless, but I was just curious to see if anyone actually had any problems.
Old Jan 24, 2011 | 06:19 PM
royce777's Avatar
im wondering this too. cuz i have a set of solid tranny mounts and i was gonan sell them but if we actually need them for the downpipe then ill have to put them on
Old Jan 24, 2011 | 07:32 PM
sjc0013's Avatar
Window Licker
Yeah, zzp says the flex section wont be warrantied if not used in combination with a mount, i just havent heard of anyone having problems not using one
Old Jan 24, 2011 | 07:33 PM
royce777's Avatar
^yeah i wouldnt want it to break lol
Old Jan 24, 2011 | 07:37 PM
GM COBALT SC SS's Avatar
interested also!
Old Jan 24, 2011 | 07:38 PM
royce777's Avatar
someone needs to buy it and find out lol
Old Jan 24, 2011 | 11:51 PM
G11's Avatar
G11
well if you guys need a solid mount top mount i got one for sale
Old Jan 25, 2011 | 10:35 AM
Sh0nuff's Avatar
I run a zzp tranny mount with mine, and I can understand why they would say what they do, the engine doesn't move like it did before, I could see a flex section not being able to handle that much engine movement.
Old Jan 25, 2011 | 03:25 PM
BWIL's Avatar
how are the vibes with the zzp mount?
Old Jan 25, 2011 | 04:24 PM
Zooomer's Avatar
Supporting Vendor
ZZP downpipes are waranted for 2 years and it doesn't matter what mounts you use or if you have changed them. Our DPs work in any config.
Old Jan 25, 2011 | 04:28 PM
coopercharge's Avatar
I use solid tranny mounts!! I like the way they feel.
Old Jan 25, 2011 | 05:29 PM
Sh0nuff's Avatar
umm the vibes are bearable.... except if you try to let out the clutch slow in first gear just trying to get going, then the whole passanger side of my car shakes like ur in one of those big ol' trucks with a granny gear trying to start out...
But past that I like it, U feel more "in tune" with the car, in my opinion... the rattling sux though
Old Jan 25, 2011 | 05:40 PM
springerdesigner's Avatar
I didn't use any mounts w/ my midlength header/dp combo.
Old Jan 25, 2011 | 06:51 PM
BWIL's Avatar
I had fitment issues with my zzp dp, the two bolt flange was welded on at an angle so it wouldnt bolt up properly
Old Jan 25, 2011 | 07:10 PM
Sh0nuff's Avatar
My dp was a little off to, comes too close to that side of the car and pressed into my heat shield, i had to beat up my heatshield to get it away from it, but it got rid of the crazy sound i kept hearing from it whenever I would get on it, it did bolt up ok though, but I thought like stock it would center out in the area for it, but it didn't.
So yeah someone messed something up along the way which made fitment kind of jacked... but mine at least bolted up ok
Old Jan 25, 2011 | 07:20 PM
ULWizSS's Avatar
DP is holding up well so far and have had multiple track runs as well. DP bolted up easy to my stock header and exhaust. Once i switched to the badmab it was just as easy. Got the ZZP front and Rear trans mount which eliminated all my wheel hop with minimal to no vibration.
Would just invest in both, i could definately tell a major difference.
Old Jan 26, 2011 | 12:10 AM
BWIL's Avatar
Mine just laid against the exhaust tunnel, I couldnt even tighten it up all the way. So its pretty much useless to me. I want a DP that fits like stock, just bigger. Is that to much to ask?
Old Feb 2, 2011 | 09:56 PM
sjc0013's Avatar
Window Licker
so the downpipes are warranted even if you dont have any aftermarket mounts?
Old Feb 2, 2011 | 10:52 PM
winning_blue's Avatar
can you just use the ingalls damper?
Old Feb 3, 2011 | 08:54 AM
I have the TTR Stop Transmission mounts. Vibes arent all that bad but I have little to no wheel hop ATM.
bigdeertz
Nov 17, 2016 09:41 AM
nathan112i
Sep 30, 2015 07:12 PM
n20saturn
Sep 30, 2015 12:26 AM
Sep 27, 2015 08:53 PM
