My amazing dyno numbers!!! Not!
Old Nov 13, 2011 | 05:02 PM
Chevycobaltss3's Avatar
This is hows he's getting 20* if his iat2s get higher then 140-150 he loses *1 timing after 10 degrees higher.
Old Nov 13, 2011 | 05:05 PM
Lol. Like i told you already shanes. What I recommend is a dual pass **** option b . Ported blower. Meth or e along with a h.e.
Old Nov 13, 2011 | 05:06 PM
shanenindy's Avatar
how should i know? lol. i'm not them. personally i would run a single pass, h/e, and meth
lol... I was asking a general question. I know your not them. I'll be waiting for the black friday sale I guess. However let me present you all with a question. I travel for work ALOT! Usually I fly, but sometimes if its practical I will take the balt on a road trip. So since E-85 isn't widely available I can't do that. Meth isn't really practical for me either for the same reasons. With that being said what would you recommend?
100% METH's Avatar
Originally Posted by shanenindy
We run 93 pump out here
Your running well outside of the m62s efficiency, and your not using e-85, race gas, or meth?
I'm going to go on a limb, your running around 16-18 psi?
- The eaton m62s optimal efficiency PSI is between 5-10 PSI, like many 60* twist roots superchargers. The greater the psi, the greater the parasitic loss.
Next, the eaton m62 charts are spun to a max of 14,000 rpm, any greater and it's outside it's efficiency range.
- You are spinning your blower by 7100 rpm to 17,750 rpm.
In a perfect world, the hp drive loss would continue linearly. But this isn't a perfect world...
Basically, your setup is counter productive using a 2.6 on pump gas. The amount of power it takes just to have the blower inlet output spit out another 100cfm IS POINTLESS if you you continue to run gas at the timing advance your able to get out of it...
Either step down to a 2.8-2.9 pulley, gain the efficiency back and the hp (in your case, 3hp difference).
or
keep the 2.6 on and toss a 5-7gph nozzle and have your tuner do what he does best.
Old Nov 13, 2011 | 05:35 PM
shanenindy's Avatar
or
gotcha thanks guys for your input! Have a pretty good idea what needs to happen, and why things unfolded as they did.
Thanks
Old Nov 13, 2011 | 06:41 PM
EXsoccer1921's Avatar
meth is quite practical actually. even if you go on road trips. when i had my setup i would drive to topeka and back(6hrs total) about every other weekend. and my 1.5 gallon tank would last about 2 months. the only reason is lasted that long was cause i'd do some spirited driving as well. i've had a tank in the car for 4 months once. just set the dial to activate the pump at say 8 or 10psi. it took me about 2 days to learn how to drive the car without going in to boost.
Old Nov 13, 2011 | 06:48 PM
**** it... Go turbo....... :P
Old Nov 13, 2011 | 07:08 PM
Leafydialupking's Avatar
Note only that. But so long as you buy your meth at a national chain, like walmart, stop and shop, or Shaws you should be able to get just about the same mixture all around the country. Unless its winter time and the people up north have switch to the super far below zero formulas.
Old Nov 13, 2011 | 07:47 PM
walmart sells methanol??
Old Nov 13, 2011 | 08:19 PM
Yeah its even pre-mixed and available in different mixtures. They also dye it this pretty blue color and sell it really cheap.
Old Nov 13, 2011 | 08:47 PM
  #36
Most methanol mixture is 18-19% I think.... So not premixed... The dye causes cloggs. So junk
Old Nov 13, 2011 | 08:49 PM
  #37
Why do so many people recommend it if it causes clogs? And it may just be up in the white north that scores the 45% meth mix.
Old Nov 13, 2011 | 09:18 PM
  #38
Yeah prob u up north. Look at it this way. the nozzle gets film from the dye which causes it to clogg. So that's why. people recommend it because its the only or there last source.
Old Nov 13, 2011 | 10:16 PM
  #39
shanenindy's Avatar
heard that!!!
Old Nov 13, 2011 | 10:26 PM
  #40
N1ckateen's Avatar
shane i think the guy that was strapping the car down in the front was putting the fan in front of the car also. i'm pretty sure if he didn't the cars would have gotten very very hot. due to that heatsoak would have set in very quickly and even from the 1st to 2nd pull numbers would have been drasticly different due to pulled timing.
Old Nov 13, 2011 | 10:33 PM
  #41
shanenindy's Avatar
no Nick I watched my videos there is no fan in front of my car in any pic or video. Not saying he didn't on any other cars, but it wasn't in place for my pulls.
Old Nov 13, 2011 | 10:36 PM
  #42
N1ckateen's Avatar
that may be the problem then lol.
Old Nov 13, 2011 | 10:39 PM
  #43
shanenindy's Avatar
Out of the cars I can only recall 1 that had the fan in place. Although I can't say my eyes were looking for it.
Old Nov 13, 2011 | 10:40 PM
  #44
ebristol's Avatar
In for all the 300whp M62s...
Old Nov 14, 2011 | 02:38 AM
  #45
my bad. i was thinking the 100% methanol race gas lol. not that "premixed" washer fluid ****
Old Nov 14, 2011 | 04:39 AM
  #46
Frogstofall's Avatar
You guys don't get HEET there in Indy-Land?
Deprecated Browser Error
Old Nov 14, 2011 | 12:20 PM
  #47
insylem's Avatar
So........ yesterday some of us Indy area guys went to a local dyno. My mods are 2.6, 60's, CAI, S3 Heat Exchanger, Ported/Polished M62, 3'' catted dp, muffler, pump gas, and Chevycobaltss3 tuned puling around 20 degree of timing.. I went into the day hoping for a conservative 270whp & 230TQ--- After many guys telling me I would be more like 280whp.. The numbers I received were not close 261.43whp & 219.55tq. As you might imagine I was a bit shocked. (scratching my head at this point) I was the first modded SC to strap in, so I waited to for more numbers. However after watching guys that had only a 2.8 CAI w/a tune put down 3whp less then myself I became a curious.
After a guy put down 259whp & 217tq I decided to ask him if he would run me from a 40-100l 3rd gear no shift same as on the dyno. He agreed--- Needless to say i walked away from him by school buses... WTF?
Now
Another member on the forums here put down 280whp & 236tq with E85, CAI, Bad-Mab Header, 3" Catted Downpipe, 2.9", 60# Injectors, Chevycobaltss3 Tuned. These are more like the numbers I actually expected.. So he also offered to run me just to see what would happen.. We made the same run twice. (Now let me remind you he is making 18whp & 17tq more then me) We pretty much stayed door to door from 30 to 110 twice in gears 2nd&3rd before letting off.
So then I shifted back to talking to the dyno guys, but they couldn't give me an explanation either in the difference in numbers. From my car we could find No belts slip... No clutch slip... Air to fuel dropped throughout the powerband... So nothing in the tune. They let me get back on for a few more pulls I made a 4th gear pull the torque increased to 240, but still only made 263whp.
Now: Im completely aware dyno numbers aren't everything, and they are all different. Im just wanting some kind of reasoning on the discrepancies here.. Could it be the dyno? The ported blower? or???
Thanks guys sorry for the novel...
Couple quick facts
Dyno Type: Dyno Jet
Rev Limit on comparison Cobalt 7100. Mine set @7200 we both hit rev on our pulls
Same size tires and wheels to comparison Cobalt
Same Tuner as well
I put down 232 with a CAI/ 2.85" Pulley, 42# Injectors and canned Tune. I was talking to some guys last week before we went to Import Face Off, and they said that the dyno that I dynoed on (Dynojet) does not put any resistance to the drum, and it just freespins. It kinda makes sence to me, if it freespins, then extra torque isnt going to show up. After the Header/downpipe install, my max boost on the dyno was about 16psi, then at the track I hit 18 psi of boost.
Old Nov 14, 2011 | 01:12 PM
  #48
In for more idiotic comments from you with your flawed reading dynograph results. Hahahaha.
Old Nov 14, 2011 | 02:12 PM
  #49
ebristol's Avatar
Ricer excuses...
Old Nov 14, 2011 | 02:24 PM
  #50
Ricer exuses. Ha. Ure the ricer.... The dyno they all used wasn't put together at all .....its not a exuse . I'm sure if the guys dynoed on the one you do they make more power then you lmfao.........
