my custom StGe 3 overviews ..
Old Sep 2, 2010 | 10:47 AM
Ryan1217's Avatar
I'm making my own stage 3. I plan on getting a custom pcm from ottp and then 80pound injectors the harness , heat exchanger... pretty much the whole ottp stage 3 but without the supercharger....the only part I'm not undertanding is the pulley...what size would be best for this setup
Old Sep 2, 2010 | 10:50 AM
Zooomer's Avatar
Supporting Vendor
what fuel you running? what is your total mod list?
Old Sep 2, 2010 | 10:57 AM
Ryan1217's Avatar
Running regular...no meth yet,...the car is completely stock n the other thing I'm puttin in with it is a typhoon CAI. Other than that there's no mods
Old Sep 2, 2010 | 12:05 PM
K-Train04RL's Avatar
just run a 2.8 with 60;s if r not going e85. extra h/e and dual pass.
Old Sep 2, 2010 | 12:06 PM
jonathan923's Avatar
with 80s run a 2.7 or 2.6
Old Sep 2, 2010 | 12:54 PM
selfinfliction's Avatar
ok so basically what you want to do is unnecessarily complicate the stage kits that are already available?
Old Sep 2, 2010 | 01:02 PM
insylem's Avatar
Running regular...
If you want any kind of performance for stage Anything,
you need to run premimum.
Old Sep 2, 2010 | 02:22 PM
Ryan1217's Avatar
well if you mean premium gas, yes i do use that and im not trying to complicate it ...i jus want the most i can get out if it
Old Sep 2, 2010 | 02:30 PM
Ryan1217's Avatar
since i dont have meth yet.... should i do the 2.7pulley with 80s n heat e/x n dual pass? because i dont think you can run a 2.6 without meth. Or should i just do 60s with heat e/x and upgrade when i go meth?
Old Sep 2, 2010 | 02:38 PM
Ryan1217's Avatar
for that i guess i just get the stage 2
Old Sep 2, 2010 | 02:41 PM
coopercharge's Avatar
ZZP stage kit would be cheaper than trying to piece together what you want 429.00 and that comes with a tune and the ZZP tune is a lot better than the OTTP tune. I say go with the canned setup ZZP has for the stage 3 with a 2.8" Pulley. Your really making things harder on yourself than they have to be.
Old Sep 2, 2010 | 04:59 PM
Karlen89's Avatar
people be talking out their ass itt.
Old Sep 3, 2010 | 04:37 PM
Ryan1217's Avatar
thanks coopercharge and karlen89 u make no sense but ok
Old Sep 3, 2010 | 04:41 PM
ecot3c inside's Avatar
get a 2.7", that should be wonderful. also run e-85 for better performance and cooling, I would tell ottp what you plan on doing otherwise there may be some faults in the vcm they send you.
Old Sep 3, 2010 | 04:42 PM
tanelk's Avatar
why do i keep reading that the zzp tunes are not good.
Old Sep 3, 2010 | 11:54 PM
Hockeyman's Avatar
you don't need 80s for the m62 unless you run e85.
Old Sep 6, 2010 | 02:53 PM
Ryan1217's Avatar
yea i keep reading the zzp tunes are not very good, would it be better to just go get a custom tune? i read when its idling its horrible. sounds like its going to stall and other problems?
Old Sep 6, 2010 | 05:32 PM
cuz there really not. i had a tuned pcm from them for my previous kit and it made my car run like ****. they sent my another one with the "same" tune for my mods i had back then and it was the same thing. not such a good experience with their tune.
Old Sep 6, 2010 | 05:45 PM
skatin_boarding's Avatar
canned tunes are canned tunes. Every car that is serious about upgrading should have a custom tune for their car.
OP- if your keeping your m62 there is no need to go with 80s without e85. Technically if your worried about your idle 80s are even bigger and will idle worse.
ineedacobaltss
Nov 7, 2015 02:25 PM
chefhhr
Oct 26, 2015 10:36 PM
patooyee
Oct 15, 2015 05:11 PM
How to Guide
57
Oct 15, 2015 11:56 AM
