My slow process to a TVS... Couple Questions
Old Apr 29, 2011 | 11:08 AM
danieluf's Avatar
I actually have the money for a TVS right now but I'm gonna take my time and make sure I have all of the right supporting mods for a good setup first so I can get the most out of the swap.
I have dual pass/option B, zzp stage 3 HE, and run a 50/50 meth mix so I have the cooling mods for my setup.
Before I purchase the TVS I want to pick up a pair of axles, an upgraded clutch, and rotated mounts so that is what I want to work on first.
I want to eventually run a TVS with a 2.8 and 80lb injectors on a 80/20 meth mix and custom tune
So as for the questions....
Do you think a pair of stage 1 axles will be good enough for a steet tvs (aka don't want to track it a lot but do engage in quite a bit of spirited driving)?
Will the upgraded GMPP Clutch hold for this setup?
Will I need a return style fuel system or will the 80's suffice?
And I have a CA header, 3'' downpipe, and 2.5'' GMPP exhaust right now but might replace the exhaust with a 3'' but will it really make that much difference?
Old Apr 29, 2011 | 11:11 AM
Rodimus_Prime's Avatar
im still on stock axles....
GMPP clutch would be fantastic, again im still on stock
60s with meth will even run a 2.8, 80s will be fine with no return
If you runnning that much boost get all 3inch and some type of longer primary header
Old Apr 29, 2011 | 11:12 AM
BLAZIN07SS's Avatar
I'm too JDM for you
gmpp clutch is holding 24psi on my bullseye s256 turbo. i think it will hold fine for you
Old Apr 29, 2011 | 11:23 AM
BLue NoTe's Avatar
Very good clutch as it turned out. I think its made by Sachs who also made the excellent dampers on this car
Old Apr 29, 2011 | 11:32 AM
Pyros777's Avatar
GMPP clutch is a SAAB 2.8t clutch with LNF pressure plate. OEM parts are always ftw in my book.
Old Apr 29, 2011 | 11:36 AM
ULWizSS's Avatar
I just bought a tvs and decided to cancel the order with zzp for a turbo swap instead.
Picked up the EFR 6758 with both custom manis from ttr at a 200 difference.
If you push the tvs past the stock pulley you will need 80's and the return for fuel from what i read.
Old Apr 29, 2011 | 11:57 AM
InfraRedline's Avatar
On gasoline you wont reach the point of needing a return style system with the TVS
Old Apr 29, 2011 | 12:09 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Just get the TVs first. If **** brakes replace it with aftermarket.
Old Apr 29, 2011 | 02:02 PM
ULWizSS's Avatar
I told ZZP i track my car a good amount. They suggested Stage 3 over 1 for me when i was a fully bolted M62 on slicks.
Old Apr 29, 2011 | 02:16 PM
RooTBeeR's Avatar
no more ABS for you!
Old Apr 29, 2011 | 02:20 PM
ULWizSS's Avatar
you following me, lol
Old Apr 29, 2011 | 02:22 PM
RooTBeeR's Avatar
newp, saw tvs in the thread title figured i'd lewk...i need to get mine back on the car, have no where local i can "safely" tune though
Old Apr 29, 2011 | 03:49 PM
danieluf's Avatar
Thats what I was hoping... can anyone confirm this? Ill pick it up if my car is dying for fuel.
Wish there was more E-85 here because I would be all over that but I only have one station in about a 20 mile radius. Sucks.
Old Apr 29, 2011 | 03:51 PM
danieluf's Avatar
How are the stock parts holding up? Is the clutch slipping at all?
Old Apr 29, 2011 | 03:55 PM
danieluf's Avatar
Good to hear. By the way, are you coming to the dyno/tune day next sat?
And I know I'll be looking for a tuner for my setup once I pick up all of the parts and I know you and Marc can tune so I might be hitting you up if you don't mind!
Old Apr 29, 2011 | 03:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
better off having marc tune you. much more local in case you need a change. i don't tune much anymore. i am trying to come to the meet but my car might not be ready. have to drop the turbo and fix the exhaust leak
Old Apr 29, 2011 | 03:59 PM
danieluf's Avatar
HAHA isn't that what everyone on this forum does...... ? is building his engine (AKA my **** broke and now I have no other options)
I don't like being stranded
Alright man, thanks anyway
Old Apr 29, 2011 | 04:39 PM
For daily driving its fine but I cant shift hard at the track it def slips the GMPP would be much better suited to what im trying to run
Old Apr 29, 2011 | 09:38 PM
danieluf's Avatar
Yea that is what I have heard.
Old Apr 29, 2011 | 09:49 PM
Dr.Balt407's Avatar
meet? what meet??
Old Apr 29, 2011 | 09:52 PM
danieluf's Avatar
Originally Posted by Dr.Balt407
meet? what meet??
You know! M-Dub is coming to tune our sh#$ haha
May 7th
Old Apr 29, 2011 | 10:00 PM
Dr.Balt407's Avatar
ooooooooyeeea i forgot, braulio told me about this. i hope i can come for this.
Old Apr 29, 2011 | 10:02 PM
danieluf's Avatar
Yea man, all of you turbo lsj guys are driving me crazy.... Met jonathan a month or so back and it sounds so nasty. Im gonna stay true to the supercharger though.
Old Apr 29, 2011 | 10:10 PM
Dr.Balt407's Avatar
lol nothing wrong with that. i would've went the tvs route but i came across a stack of cash and i never had a turbo car before so i was like why not now
Old Apr 29, 2011 | 10:12 PM
danieluf's Avatar
Ahhh nothing like a good ole stack of cash
