a Nasty sound...
a Nasty sound...
Ok... well i know its something to do with my s/c... when i hit the gas, a nasty noise comes from where i beleive is my intake manifold... It sounds like a old diesel... I think i may have lost boost, i dont drive fast enough to tell for sure at the moment... But it wont make the noise when its outta boost... Gasket maybe?
Anyone have this happen?
If you're hearing a loud sound it's likely an exhaust leak...check your exhaust flanges and the flexpipe.
I will check for both things tomorrow... im leaving my car home till about 530 then taking it to the mechanic, ill have them look at those things...
Thanks! Anybody else have something?
bump...
What would happen if an injector stopped working or possibly one of the electrical connections came off the vacuum valve on the s/c? Would it make a crazy noise?
the noise is seriously like, standing next to a harley, but a little quieter, it makes that same rumbling noise, like i have a v6 under the hood with straight pipes...
i have this exact same problem now too, makes the terrible noise when i accelerate but only during boost, and it's not the coupler. usually when the coupler goes out the sound is present only at idle, more like rocks in a can or cup or something. hence i think it's the gasket, flexpipe, or dp leak.
