Nathan's build thread again.....
Old Jun 18, 2009 | 12:20 AM
Angel's Avatar
450whp Goal turbo build
Ok, here we go round 2. We had to rip into the engine somewhat because my timing belt and tensioner went up **** creek w/o a paddle. I was going to wait until winter to do this but plans changed now. Right now we have the head out of the car. The block and tranny are coming out right soon as well. Currently we are running the Hahn stage V turbo with the s20g turbo with full Hahn 3" exhaust with high flow cat, Devils own progressive meth kit running 90/10 mix sprayed in via throttle body spacer from OTTP. Other mods currently done on the car performance wise are Centerforce dual compression clutch w/lightweight aluminum flywheel, OTTP stage 1 axles, OTTP stage 2 rotated mounts, OTTP steering rack spacers, H+R 2" drop coils, Koni shocks all around, teflon braided yellow brake lines, Hawk pads, slotted rotors, O.Z. Racing Ultraleggerra 18" w/BFG g-force rubber(235/40R/18), CA Carbon Fiber SS hood, CA Carbon fiber highrise center section w/end caps, IPCW tailights(tinted), 3rd brake light/side markers(tinted), 3rd gen projector headlights w/8k HID's(hi/low/fog lamps), TMW short shifter w/weighted shift knob, MOMO ebrake handle w/MOMO leather boot, GM white hood/trunk struts, MRZ Performance billet caps(black-all caps under hood+custom Hahn Racecraft plate on fuel rail cover, Graphite metallic sprayed fuel rail cover+fuse panel cover+coil cover. Audio-Eclipse SC8365 components, SP6510 coaxles, 2-ZA1200's, 1-XA4200, 2-SW8210's, AVN726e w/ipod cable, Tsunami 5 farad capacitor, Eclipse back up camera, Soundstream 7" overhead monitor. Security.Remote start-Clifford 50.7X. Aeroforce interceptors(dual in custom made dual gauge bezel), Autometer wideband air/fuel gauge, Autometer ______????, Autometer ______???(Triple gauge pillar---waiting on 2 more gauges for fill!), Modern Performance billet shorty antenna, rear 3 windows 5% tint, New turbocharged upper/lower grill assembly, shaved bowtie on front bumper(replaced with "SS" badge), Led million color underglow(SHOW ONLY!!! I dont drive around with that crap on so no hating--no choice on my end.lol)
In the works......
-Heads going in to be CNC'd/Ported/Polished (WORK IN PROGRESS)
-OTTP Supertech 78lb Valve spring kit (ARRIVED!)
-OTTP Supertech Ecotec Stainless/Inconel Valves(0.5mm oversize) (CHANGE PLANS - STOCK VALVES- VALVE JOB IN PROGRESS)
-OTTP Cometic MLS Head Gasket 2.0 (ARRIVED!)
-OTTP ARP Ecotec Head Studs (ARRIVED)
-Comp custom cams (CAMS ORDERED VIA BATES ENGINEERING---COMP CURRENTLY GROUNDING CAMS!)
-MRZ billet aluminum lightweight crank/alternator pulley (ALTERNATOR PULLEY ARRIVED, CRANK PULLEY JULY 10TH)
-OTTP Return Style Fuel System Kit (ARRIVED!)
-Lucas 42lb injectors (DELETE--CHANGE OF PLAN)
-Bosch inline bullet style fuel pump(used in conjuction with factory pump)---(CHANGE OF PLAN/JOSH@OTTP IS CUSTOMIZING FUEL CELL TO HOUSE 2 FACTORY STYLE FUEL PUMPS--LESS NOISE THIS WAY)
-Hahn port fueler system with controller (DELETE--CHANGE OF PLAN)
-GReddy Spec II Boost controller (ARRIVED!)
-Punched out high flow cat
-180amp alternator(2.4 alternator-no welding required) (ARRIVED)
-2 Kinetic HC1400R batteries (ARRIVED)
-Relocated washer fluid resevoir
-Relocated K+N air filter(passenger side-where washer fluid resevoir was) (HAHN SHIPPED ADDITIONAL PIPING+COUPLERS FOR RELOCATION)
-Turbosmart Supersonic bov(replacing current turbosmart bov) (IN TRANSIT)
-OTTP Siemens 80lb fuel injectors w/harness (ARRIVED!)
-OTTP Diamond forged pistons(stock 9.5:1 compression)
-Honed block (work in progress)
-OTTP Copper exhaust gasket (ARRIVED!)
Pictures coming soon!!!!!!
Ohh, and btw we have a new timing chain + revised tensioner coming as well
Old Jun 18, 2009 | 01:03 AM
rocketrex's Avatar
Wow I'm impressed. Congrats
Old Jun 18, 2009 | 01:27 AM
Angel's Avatar
Thanks
Old Jun 18, 2009 | 01:29 AM
06_SIC_SS's Avatar
yeah man it is awesome.. u need a black a/c control deck really finish that dash with it..,ake it pop
Old Jun 18, 2009 | 01:38 AM
Angel's Avatar
Any ideas on where to get one?
Old Jun 18, 2009 | 01:50 AM
drew1991sf's Avatar
42s? y would u use those on stg5 turbo kit
Old Jun 18, 2009 | 01:57 AM
Hockeyman's Avatar
^I was about to ask the same thing...Hahn lvl 5 with 42s?
Old Jun 18, 2009 | 02:27 AM
Angel's Avatar
lol. I should have clarified that. The initial Hahn stage V system came with the 60lb injectors and now we are sending back the intake manifold to have the brackets welded onto it for the port fueler option, so we are going to be running a second fuel rail with 4 more injectors in it which are going to be the 42lb injectors and the 60lb injectors stay in the stock location. So a total of 8 injectors @ 408lbs total hence the reason for the second inline fuel pump.
Old Jun 18, 2009 | 04:08 PM
Angel's Avatar
Also, I forgot to note that our goals upon completion are 450whp.
Old Jun 18, 2009 | 04:10 PM
ShortStack's Avatar
You might have to switch turbos for that one.
Old Jun 18, 2009 | 04:15 PM
06_SIC_SS's Avatar
i got my black a/c control deck off of ebay for 10 bucks..u can find em cheap..plus.. dont take the entire system out..just take faceplate off the one u buy and pop it on the current one..quick and simple change..itll make it look perfect..i couldnt be happier with mine.. i just painted my interior trim.. i have a couple pics in my gallery <--
Old Jun 18, 2009 | 05:22 PM
RednBlack's Avatar
kinda off topic but where did you get those floormats i want em! edit; im blind seen the logo and found them! nice car btw
Old Jun 18, 2009 | 05:43 PM
Angel's Avatar
Lol, yeah these are the best floormats ever for our cars!! I actually bought them from one of my suppliers.
Old Jun 29, 2009 | 12:13 PM
rocketrex's Avatar
edit/ sorry i was look at ur other thread nt this one lol so what was the trickyst part of this whole switchover?
Old Jun 30, 2009 | 01:03 PM
my god what a beast
Old Oct 6, 2009 | 12:32 PM
Kemble's Avatar
I'm totally getting those floor mats. Definitely need rubber mats for Michigan.
Old Oct 6, 2009 | 07:04 PM
terry11's Avatar
Dude how is your piping run? I love how it's hidden and how it comes from the existing intake location. I'm doing a custom turbo kit soon and would love for it to be just like that
Old Dec 23, 2009 | 01:56 PM
rico's Avatar
ill let u know. i got his kit and will be installing soon ill take plenty of pics
Old Mar 11, 2010 | 02:22 PM
hungryhip-ccp's Avatar
looking good bro, link for floormats? really interested!
which cams the turbo grind? or a custom turbo grind?
Old Mar 11, 2010 | 04:33 PM
rico's Avatar
hungry u ever get those new cams u got in?
Old Mar 11, 2010 | 04:49 PM
no they sent me an email saying they didnt charge my card cause it was gonna be 2 weeks + and they would re invioce me then if i still wanted them. but now i have decided to go twincharged instead for about the same price. and completely eleminate lag!
Old Mar 11, 2010 | 06:57 PM
Slammed07's Avatar
Wow man, I'm impressed good job the car looks great! I want a set of those floor matts!!!!!
Old Mar 11, 2010 | 07:01 PM
Texas SS's Avatar
Sounds like a good build
and AWSOME FLOOR MATS lol
I want some
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
riceburner
Oct 2, 2015 05:47 PM
nathan112i
Sep 30, 2015 07:12 PM
