Need all fluids for a rebuild of the engine
Oh ****, you did a big teardown! Get 6 quarts of regular break in motor oil (not synthetic for the first time), a big bottle of DOT 3 or 4 brake fluid (whatever's on the cap since I forgot), one bottle of GM supercharger oil, some Melling engine assembly lube, 2 quarts of Royal Purple Max Gear 75W-90 transmission fluid, and you should be set my friend.
if you need s/c oil an dont want to pay 11-15bucks for 6qrt from gm go get motor oil 5w30 its the same **** pretty much just a lil helpful hint incase you didnt wanna spend60+ on gm s/c oil
-Brad
No one mentioned Loctite and Neverseize. There's several types you'll want. One is thread sealer (567) for bolts that you don't want fluids to leak in or out of. Thread locker (red 277) is for bolts you don't want coming out . and Last one is flange sealer (510) for like the valve cover. Also threebond 1280B-GM liquid gasket sealer for the oil pan. CMD high pressure lube for bolts that require critical proper torquing like head studs. Hope these help. Also maybe even some spark plug grease for that last bit of spit shine.
patooyee
Oct 1, 2015 01:07 PM
