Need a fitting radiator 06 cobalt ss sc 2.0l
Old Oct 27, 2019 | 05:16 PM
LilHalfCut's Avatar
I need a new radiator as my current one may be a bit oversized and loose cause it drags bad sometimes. I'm also on 2 inch lowering springs (On the search for new coilovers as well if anyone has recommendations) so that doesn't help. I cant seem to find any good choices for this model that would fit and be affordable. Any help??
Old Oct 28, 2019 | 11:59 PM
bubba_jay's Avatar
Get rid of the 2" drop springs, for starters. Then get some YYZ's from Powell.
Problem solved.
Old Oct 29, 2019 | 08:49 AM
jdbaugh1's Avatar
Like I said in your other thread (which appears to have been ignored) I don't see how it's possible your radiator is dragging. The radiator sits on top of the front subframe. Can you take a picture of whatever it is that is dragging? I'm guessing front mount aftermarket heat exchanger.
Old Oct 29, 2019 | 09:50 AM
JD is right, would be pretty hard to scrape the radiator with the way its mounted.
Old Oct 29, 2019 | 09:19 PM
LilHalfCut's Avatar
You're probably right, I can get some pictures tomorrow for you
Badbren_ss
Feb 19, 2016 05:57 PM
Badbren_ss
Feb 18, 2016 05:46 AM
06cobaltncng
Apr 3, 2014 10:03 PM
SS1
Sep 24, 2012 12:08 PM
justin04
Mar 17, 2007 11:20 PM
