need help.
I looked at all of them even the lil bigger looking ones and looked all good
yeh i have hpt and i haven an 07
This sounds like the mistake I made last time I changed my clutch.
Put back one fuse in the wrong spot (leaving a real fuse spot empty, can't remember which one), and I had the exact same problems.
Write a tune with the VATS turned off (since you think the computer is bad, not really risking anything), then try jumping the starter with the key in the run position.
Mine would start like that.
If yours does you probably have either a fuse or a wiring problem.
Kevin
Kevin
what would cause that? how would i fix it?
car was working fine and out of no where started doing all this...
bump anyone got more ideas for me to try when i get home or anything? lmk im really thinking its the ecu tho
i would say ECU thats what they replaced on my car when my fan would stay on and wouldnt crank......after i put that piggyback chip on it. they really couldnt figure it out, so they called me and were going to replace the ECU. they did that and i was driving it the next day...i have no clue on how to tell if its fried or not. maybe take it to the dealer and ask them if they can run a test to see if its fried or not?but im most certain its the ECU
I still believe the theft module could be the culprit. when i had my 06 LS the module shorted and the car wouldnt start. the passlock light wasnt lit and anytime i tried to start the car the DIC would go nuts. bridged the starter and it would start, but die seconds after.
and what was the fix?
well my puertorican ass has had a BLONDE MOMMENT and i dint think about the inside fuses. i checked fuse box in the engine bay but not the ones inside the car
so ill do that when i get home and hopefully thats the problem
not the fuses so umm
i did get a security icon now tho. after messing wit fuses earlier and all but even before that it still did all the stuff i said yesterday
dont see this anywhere
oh well i tried doing a whole write up with hpt and it didnt help . but ill know soon as soon as my friend gets to it at the dealership lol he towed the car with him lastnight to take it with him today to work
car is alive i was told
