Need help with exhaust ......
Old Sep 9, 2006 | 09:32 AM
SilverSS/SC's Avatar
The flex joint in my stock downpipe started to separate and is basically about to fall off . I have a ZZP downpipe on the way , but in the meantime I have alot of damn miles to drive before the new pipe gets here . Its sounds like old VW bug underwater
The stainless steel on that flexjoint is too thing to weld . So I tried a cheap exhaust repair kit . Which lasted for about 10 miles . Anyone got ne ghetto fabulous ideas that might last me at least a couple days or 1 full day at least .
Old Sep 9, 2006 | 09:41 AM
StinkBOMB's Avatar
JB Weld?
Old Sep 9, 2006 | 09:42 AM
I thought bout that but I think it would just blow it out . To bad its gotta be on the damn flex joint ....grrrrrrr
Old Sep 9, 2006 | 09:44 AM
StinkBOMB's Avatar
It's worth a shot right? I mean your alternative is to just ride around with a hole in it. What do you have to lose?
Old Sep 9, 2006 | 09:48 AM
D4u2s0t's Avatar
that's bullshit... i would say to have it fixed, but you're getting the new one, so guess it's all good... if it's very temporary, i would fix it up any wayou you can.... duct tape??
Old Sep 9, 2006 | 09:57 AM
The prob with nething with adhesive on it , it burns the adhesive off . The exhaust repair kit I tried had alumiunum tape , and I wraped the hell out of it . Once the adhesive burned off in like 15 minutes it jus rattled on there .
Prolly will give JB weld a shot , I gotta leave this afternoon
Old Sep 9, 2006 | 10:08 AM
WickedSS2005's Avatar
Use JB's Waterweld kit. It's a tube that you cut a piece of product from, rolld together mixing the two substances and is totally handle-able (werid sounding lol) fro 2-3 min b4 it starts to harden. Is hard in 20 min. Fixed my exhaust leak with it and love it.
Old Sep 9, 2006 | 10:13 AM
cool deal , I will try that ....thanks
Old Sep 9, 2006 | 10:18 AM
HackAbuse's Avatar
aluminum foil?
Old Sep 9, 2006 | 10:21 AM
Matty's Avatar
Originally Posted by HackAbuse
aluminum foil?
Why not, it works for baked poatoes.
Old Sep 9, 2006 | 10:30 AM
suburbanrobot's Avatar
old trick
a thin sheet metal you can bend, wrap it around the leak and use metal hose clamps (1 at top and 1 at bottom)... I have done this as a temporary fix years ago on an 390 V8 LTD .... but have never tried it on a flex joint.....maybe aluminum tape or the JB weld stuff underneath the wrap? if you do the JB underneath... let it harden before you do the wrap.... make sure you don't get the JB weld inside the tubing as it might snap off inside and be stuck in your exhaust.
good luck
Old Sep 9, 2006 | 11:37 AM
I ended up getting a epoxy weld stick . "Bonds any metal permenantly" and good to 500* . Im not optimistic , lol ....guess well see .
The ZZP pipe will be here Monday thank god .
Old Sep 9, 2006 | 11:43 AM
Allshot's Avatar
If it was your stock downpipe why didnt you have the dealer give you a whole nother one. Just in case the zzp doesnt sound to good.
Old Sep 9, 2006 | 11:52 AM
No cat in mine .
Old Sep 9, 2006 | 11:54 AM
Allshot's Avatar
Oh ok now I got ya.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
