Need help fast!!!
Old Aug 15, 2008 | 10:51 AM
sicksilverss/sc's Avatar
Question Need help fast!!!
I am putting an injen intake on in about an hour and i dont know where i should mount the meth nozzle. Where it is mounted on the stock intake it would be at the begining of the intake where the rubber boot is. Where should i mount it?
Old Aug 15, 2008 | 10:52 AM
Altiery54's Avatar
do u put meht on ur car? or is everything still factory stock?
Old Aug 15, 2008 | 10:53 AM
lsjwannabe's Avatar
Put it 6~8 inches before the tb
Old Aug 15, 2008 | 10:55 AM
Altiery54's Avatar
^^ lol. from the sound of it i thought he was stock and thought it came the factory with meth
Old Aug 15, 2008 | 10:57 AM
Im using meth its just that i had my stock tubing and i cut off my airbox so it was like a cld air intake. I just bought the injen just for the looks but when im about to put it on i noticed that the posistion that it is in now is right where the new intake connects clamps to the rubber boot. Should i mount the meth nozzle in the rubber boot or right at the begining of the ijen intake after the boot.
Old Aug 15, 2008 | 10:59 AM
Altiery54's Avatar
if u can wait for a week order a TB spacer from ottperformance so u dont have 2 mount it into the intake
i bought one and its great man works like a charm and when u part out u can still sell the intake unlike if u had 2 mount the meth nozzle in the actual intake
wow i'm an idiot. u put it in the coupler?
Old Aug 15, 2008 | 11:00 AM
Well i need to do it today because i am getting tuned again tomorrow morning.
Old Aug 15, 2008 | 11:03 AM
Altiery54's Avatar
well search for the meth thread by colejjones it shows exactly where to mount it
here ya go
https://www.cobaltss.net/forums/show...highlight=meth
Old Aug 15, 2008 | 11:07 AM
Thats where i have it mounted now. I need to either move it closer to the vacuum hole or on the rubber?
Old Aug 15, 2008 | 11:13 AM
brett5's Avatar
hey i have the same thing injen gives you that little rubber piece for after the throttle body and then the metal intake ...its actually easier this way i just drilled right into the rubber and right in the middle and put it there and it works fine...rubber on rubber also makes a good sealant.
i acutally took the check valve off because there was no need for it there.
they only say to mount it that far away do to the vaccum when you don't want ot spray it may get sucked in but like i said i've been running this set up now for like 3 weeks no problems...i had the check valve in there and for some reason it like stopped the meth froom flowing period so i took it out and i have had no problems with meth getting in there when i don't want it to
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Sep 29, 2015 03:56 PM
Sep 27, 2015 08:53 PM
no_ss
Sep 18, 2015 11:03 AM
