Need help fast!!!
I am putting an injen intake on in about an hour and i dont know where i should mount the meth nozzle. Where it is mounted on the stock intake it would be at the begining of the intake where the rubber boot is. Where should i mount it?
Im using meth its just that i had my stock tubing and i cut off my airbox so it was like a cld air intake. I just bought the injen just for the looks but when im about to put it on i noticed that the posistion that it is in now is right where the new intake connects clamps to the rubber boot. Should i mount the meth nozzle in the rubber boot or right at the begining of the ijen intake after the boot.
if u can wait for a week order a TB spacer from ottperformance so u dont have 2 mount it into the intake
i bought one and its great man works like a charm and when u part out u can still sell the intake unlike if u had 2 mount the meth nozzle in the actual intake
wow i'm an idiot. u put it in the coupler?
well search for the meth thread by colejjones it shows exactly where to mount it
here ya go
https://www.cobaltss.net/forums/show...highlight=meth
here ya go
hey i have the same thing injen gives you that little rubber piece for after the throttle body and then the metal intake ...its actually easier this way i just drilled right into the rubber and right in the middle and put it there and it works fine...rubber on rubber also makes a good sealant.
i acutally took the check valve off because there was no need for it there.
they only say to mount it that far away do to the vaccum when you don't want ot spray it may get sucked in but like i said i've been running this set up now for like 3 weeks no problems...i had the check valve in there and for some reason it like stopped the meth froom flowing period so i took it out and i have had no problems with meth getting in there when i don't want it to
