need help fast
Old Sep 4, 2007 | 01:06 PM
madmark's Avatar
need help fast
im working on a ss sc at work and i cant get the stock pulley off. i need help asap because im leaving soon.im using a pulley removal tool but its not working to well. and i cant search to much because of work websence
any help plz?
help???
Old Sep 4, 2007 | 01:36 PM
Area47's Avatar
Rent me! per hour
is the blower off the car? it is a long drawn out process with the puller.
Old Sep 4, 2007 | 01:38 PM
Projekt's Avatar
what me and my buddy did is use a screwdriver and push the pullies down to release slack on the pulley it self..that should make it come off but its hard as hell and hurts if u let go!
Old Sep 4, 2007 | 02:19 PM
RedlineBrian's Avatar
If you guys have a press you can use that to get the stock pulley off.
Old Sep 4, 2007 | 03:02 PM
rallycobalt06's Avatar
so hold up..... you have to remove the supercharger to pull off the stock pulley?
Old Sep 4, 2007 | 03:05 PM
SSdan's Avatar
Yessum or bitch because its a major PITA without removal, if even possible.
Old Sep 4, 2007 | 03:07 PM
well taking the supercharger off really isn't that hard is it? the pulley is the biggest PITA right?
Old Sep 4, 2007 | 03:21 PM
madmark's Avatar
its not hard it is just alot of steps. I did have the supercharger off the car. frank parra didnt have the tool j-38416-1 i think which is the proper tool to remove the pulley. we had a pulley remover, but the end was circled just as big as the sc snout (the center piece) so we put a socket on the end of the tool and it was stripping out the socket. so i said **** it and told my friend i wasnt doing it and put it all back together
Old Sep 4, 2007 | 04:46 PM
rnjmur's Avatar
The easiest way to get the pulley off is with a press. Other wise it is a real bitch. I don't think there is anyway you could ever get the stock pulley off the SC without removing it first.
Old Sep 4, 2007 | 05:23 PM
clutchmaster's Avatar
s/c off goto pep boys and rent the tool for like 10$.... i had great help (chevysalesman) edit- he did it. i learned watched. lol.... we took off s.c and then took it to pepboys and used his buddies air gun... and used the tool and just popped it off... then gotta a rubber mallot and slammed the zzp hub on with some grease and elbow grease lol... good luck!!
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Sep 29, 2015 03:56 PM
Sep 27, 2015 08:53 PM
no_ss
Sep 18, 2015 11:03 AM
