Need help with Intense stage 3
Old Mar 9, 2006 | 02:41 PM
2005yellowss's Avatar
I installed the stage 3 and did the boost bypass mod everything seems to be running right but i am having problems with the A/F.
I make a wide open throttle run through 2nd and get 12's in the wideband and sometimes 11's. Then i shift to third and go WOT it runs good about half way through the RPM range with 11's in the wideband then it dumps to 10's and just stays there and the power is gone. I have messed with the wot setting on the maf t but cant seem to get it right. I have gone 2%, and 4% rich and 2%, 4%, and 6% lean but I just cant seem to get anything to work.
Can anyone help with this, am i doing something wrong.
Thanks
Old Mar 9, 2006 | 02:54 PM
Ljavy17's Avatar
please read my post about the settings, it happens when your car gets too hot and ur pcm kicks in, You can fix this by turning the car off and back on each time, itll reset the PCM. also, leave it where you see 12s in 2nd and 11s in 3rd gear thats the best and safest youll get. If you see it dump to ten after a run lets say like up to 120mph then turn ur car off and when you turn it back on itll be runing fine.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
