Need help with my afr's and meth injection!
k sounds good thanks for the advise.... i already have 60's on the way there should be here tomorow.... all i have to do now is figure out why my gauge isnt working???? do you think i ruined the sensor because of it being so rich? i only used it for one day....
the sensor i just through in the o2 bung and old way, and i had my power from my boost gauge but tommorow im gunna wire it to my fuse box instead to see if that will make a diff.... do you think it will???? ya im getting a tune asap!!
to quote an expert tuner with meth from this site...
"a tuned car with meth will always make more power than an untuned car with meth"
the factory tunes put our afr's in the 10s to begin with. add meth, and watch it plummet. you didnt fry your sensor after one day. its all good.
Glad to hear you worked out the WB issue, and that you are getting tuned. You'll notice a nice difference.
i had an aem wideband. at WOT it read 10.0 and i was like oh ****! im running hella rich. but when i got my new wideband it read 11.6. then i was like oh ****! my sensor was fucked up. you might have a bad sensor dude. and put your check valve as close to your spray nozzle as possible
