NEED HELP from our engine savvy members
Old Nov 6, 2007 | 01:03 PM
roadrage06's Avatar
I am not as engine knowledgeable as I'd like to be. I need the help of those who are...
I am finally looking at Staging the 'balt. I've read threads on here debating the size of pulleys and air to fuel ratios that state what can and can't be run saftely on our s/c's. I definitely am not one of those tuners who want the max amount of power, even if it means my car is only going to last 6 months. So here are my questions:
1. What stage kit of Cobalt Addiction is a good, safe setup (what is the highest out-putting setup that can be built safetly)?
2. When do headers, downpipe, and exhaust become essential... basically, can they wait till after staging, because I'm foaming at the mouth for that big hp jump.
3. Any other info that my questions do not address, that I need to take into consideration, feel free to add.
Thanks.
Tom
Old Nov 6, 2007 | 01:10 PM
sick06cobalt's Avatar
1. honestly I would go with stage two with a 2.8 pulley.... i would look at gmpp also not just CA
2. You want to add exhuast to add more flow to the system... since you have an intake youll want to add an exhuast set up for more flow because without it, your bottle necking your system.. more flow = more power... They can wait till after staging... to your desire basically...
3. youll want to jsut make sure that youll have some way to keep all of this cool.. these cars are known for their heat soak... so do siome cooling mods too.. IMO...
So thats my .02...
- Dave
Old Nov 6, 2007 | 01:16 PM
thedubsack85's Avatar
Thanks.
Tom
well look at it this way you cant get a serious stage kit without serious supporting mod's.
^ is right thow more flow more power. do stage 2 with a 2.9 depending on altitude you may be able to run a 2.8 then do header DP full exhaust and i say a heat exchanger to keep iat's down so you can make power on a high speed run cause of NO heatsoak..
it aint nicknames the heaton blower for no reason.
Old Nov 6, 2007 | 01:42 PM
hiPSI06's Avatar
i suggest stage 2 from gmpp, warranty friendly and you can always slap on a smaller pulley...im runing gmpp stage 2 with a 2.8 and i loveee the power. my next step is cooling mods for sure
Old Nov 6, 2007 | 01:44 PM
roadrage06's Avatar
ok, and to increase my knowledge of my car: what makes anything smaller than a 2.8 pulley bad?
Old Nov 6, 2007 | 01:48 PM
IDC(injector duti cycle). and intake air charge temp....
Old Nov 6, 2007 | 01:53 PM
roadrage06's Avatar
haha. and that means...?
(see original post for why explanation is needed...lol)
Old Nov 6, 2007 | 03:44 PM
It means that the stage 2 injectors cant do that much work with anything lower than a 2.8... a 2.8 depending on your altitude can either be perfect for the reflash or it can be streching it... usually your best bet is 2.9 but the 2.8 will get you more power and should be fine on the reflash from the dealer... and anything lower than a 2.8 causes the engine to work really hard so that the Intake temps will be really high... not good.. hence why we suggested some supporting mods... especially with anything lower than a 2.8 your gunna wanna run a water meth kit and a H/E...
Old Nov 6, 2007 | 03:54 PM
roadrage06's Avatar
Ok,
1. I'm in Pennsylvania, how's my altitude.
2. CA sells a kit with a 2.85 with 42# injectors
2a. would it be better to get the GM stage 2 and then buy a 2.9"
2a1. who sells a 2.9"
Old Nov 6, 2007 | 04:01 PM
haha... as far as #1 ask someone from PA and see what they have... lol im in MO so....
2. Go with the gmpp stage 2 kit and get a 2.9 the best bang for your buck in my oppion...
2b.. no idea, I think intense might...
Old Nov 6, 2007 | 04:04 PM
roadrage06's Avatar
ha, alright, thanks.
When I research my altitude, am i looking for what the air density at my altitude is?
Old Nov 6, 2007 | 04:28 PM
Sw4y1313's Avatar
Dont waste your money on stage 2. Buy stage 1, get it installed by your dealer, then buy the 2.9 pulley + hub for $100 and GM Stg2 Belt for $40. Saves you a lot of money in the end for the same thing because the GMPP Stage 1 comes with the stage 2 reflash and injectors. You save money by buying your own hub/pulley/belt.
Old Nov 6, 2007 | 05:47 PM
FryLoch's Avatar
Stage 1 doesn't raise the redline like stage 2 does.
Do stage 2, get the stage 3 pulley.
Get the GMPP exhaust
Then do a dual pass setup, that's my next mod.
Old Nov 6, 2007 | 05:48 PM
Sunburst_SS's Avatar
wrong....I have the stage 1, and my car has the 7k redline
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Dirtybutwhole
Sep 26, 2015 06:53 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
