need help with shift light install
Old Feb 19, 2006 | 10:21 AM
bigjoe25's Avatar
I bought a Stewart Warner shift light. I got the power and ground hooked up just fine. The problem I am having is with the green wire that needs to be connected to the coil negative. I hooked it up to the brown and white wire that was suggested in the other thread, it worked but the rpm's didn't match. Also, it requires that the PPR (pulses per revolutions) need to be set. Does anyone have any idea what the PPR for a Cobalt SS-SC would be? Any info would be greatly appreciated.
Old Feb 19, 2006 | 11:59 AM
bigjoe25's Avatar
No matter what I hook it up to, it is off by half across the rpm range.
Old Feb 19, 2006 | 12:46 PM
NJBLUESS's Avatar
Your ignition system is COP, coil on plug. You will need to set the cyl. scale to 1.
Old Feb 19, 2006 | 01:25 PM
BlackSS05's Avatar
yes if it has a one cylinder setting then you will be fine. If it doesnt it will not work with the COP. if you can't get it to work go to raptorperformance.com and order one from them.
Old Feb 19, 2006 | 04:18 PM
bigjoe25's Avatar
ok the instructions say to hook the green wire to the coil negative or the tachometer terminal so where would the tach terminal be?
Old Feb 19, 2006 | 10:09 PM
BlackSS05's Avatar
there isnt one since your car is coil over plug. we run a distributorless ignition system. the only way the light will work is if it has a one cylinder setting since each plug is its own seperate entity. if you have nemore questions send me a pm i will be more than willing to help u.
Old Feb 19, 2006 | 10:26 PM
JAESS's Avatar
The ppr needs to be set at .5 If you have part# 114906 you will have to send it back. You need part # 114926 because the first one only goes to .1. The second part # witch is more expensive goes to .5. There is a other Sterwart warner gauges that go to .5 I just don't know there part #. I do know that the 114926 goes to .5 because thats the one I have.
Joe
Old Feb 20, 2006 | 05:54 AM
bigjoe25's Avatar
i thought that was the problem thanks for the info guys i will take it back and get the one that goes to .5-ppr
Old Feb 20, 2006 | 02:00 PM
zinner's Avatar
Moderator Alumni
If your tac doens't have a single cylinder setting your going to need a tach adapter.
MSD tach driver
Old Feb 20, 2006 | 10:21 PM
bigjoe25's Avatar
i looked into it and just took the shift light back i am going to get another one tomarow
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
