need help with some questiions
Old Apr 3, 2009 | 03:15 PM
1newZX2's Avatar
soon i will doing alot of work to the cobalt and i had a few questions. thanks for all the help.
i plan on making a dual pass endplate out of my stock one. i think i read some stuff about how you have to switch the lavacores around when running the dual pass.....?
im also adding a zzp heat exchanger. on the stock exchanger does it matter which posts is the input or output or is it universal flow? if the stock on is universal im assuming the zzp one is too.
i purchased a aem wideband and a aeroforce interceptor. can i power the factory boost gauge and both of those gauges off the pink power wire for the factory boost gauge?
those are just a few that i can think of. im new to moding the balt
Old Apr 5, 2009 | 08:36 PM
1newZX2's Avatar
wow no answeres????
Old Apr 5, 2009 | 08:38 PM
scott allen's Avatar
ok cool
Old Apr 5, 2009 | 09:02 PM
coopn8r's Avatar
Power your Interceptor in your Sunroof and but it in with the fuse.. Power the Wideband on something else.. Like powersource.. They need there own Power Sources otherwise you'll just blow fuses :P
Old Apr 5, 2009 | 10:13 PM
1newZX2's Avatar
hmm i already have my meth pump on the sunroof. is there any other switch sources for 12 volt....
Old Apr 9, 2009 | 12:15 AM
1newZX2's Avatar
so to power everything i will ever want for my car this is what i came up with.
using a minifuse power tap for the sunroof fuse. use this wire as my signal wire for my 30 amp bosch relay. and run 8 gauge power wire to it and out of it that way i will have enough power to power everyhting gauges/pump/etc all future 12 neccesitys ill want.
agitator
Aug 6, 2012 12:12 PM
blown06SS
Jul 15, 2007 08:29 PM
UpOnGaMe
Oct 6, 2006 07:40 AM
