Need Help!!!! Transaxle
Old Jun 3, 2009 | 08:17 PM
valentino0214's Avatar
im trying to removed the stock transaxle on the passenger side..... but wont come out
bump no1???
Last edited by valentino0214; Jun 3, 2009 at 08:17 PM. Reason: Automerged Doublepost
Old Jun 3, 2009 | 08:44 PM
SS/SC Crazer's Avatar
did u remove the 2 or 3 bolts that hold the bracket on? from the trans, follow the axle to the right and you will see an aluminum piece that it goes through, well it doesn't go through it, it is a bracket, remove the bolts and it should slide out, if not than wiggle, pry lightly, tap lightly with a hammer, do what you got to do. mine almost fell right out!
Old Jun 3, 2009 | 09:15 PM
i did that part.... how do i get the trans axle out of the shaft though thats where im stuck
Old Jun 3, 2009 | 09:20 PM
shutzero's Avatar
do you mean the stock axle? a transaxle is a front wheel drive transmission...so your post is extremely confusing.
Old Jun 3, 2009 | 09:54 PM
ok then the stock axle out of the center shaft???
Old Jun 3, 2009 | 09:55 PM
Old Jun 3, 2009 | 10:09 PM
shutzero's Avatar
ya you gotta hit it with a rubber hammer and just work it out. you did pull it out of the hub first right?
Old Jun 3, 2009 | 10:35 PM
yeahi just dropped the top nuckle from the strut.. and then i ripped the axle off and got the piece that goes into the center shaft
do i take the center shaft out?
Last edited by valentino0214; Jun 3, 2009 at 10:35 PM. Reason: Automerged Doublepost
rukkee
Feb 28, 2008 01:13 AM
Witt
42
Feb 7, 2008 04:31 PM
