Need info on 2007 SS/SC Exhaust system
Old Dec 2, 2008 | 10:42 PM
ReckleSS's Avatar
Did some searching around, but really did not find any particulars.
Anyone know the specifics about the factory down pipe and catback on the 2007 SS/SC?
Diameters?
HP gains with aftermarket catback?
Worth it to gut the cat at first?
Is the catback good enough to support 250whp?
Any info greatly appreciated.
Old Dec 3, 2008 | 10:21 AM
dhall1973's Avatar
I am very interested in this as well. I would like to go to a 3 inch catback exhaust?
I do not want to loose any power?
Old Dec 3, 2008 | 10:25 AM
PhantomSS's Avatar
2.25 catback supports 250+ whp itself. Im also using vibrant shorty+hiflow dp.
3--->2.25
If your going bigger than the m62 get 3, otherwise no larger than 2.5 or you will lose hp...and you will lose torque already.
Old Dec 3, 2008 | 10:30 AM
SilverSurferSS/SC's Avatar
Size exhaust depends on your plans for the car.
stock can support ~250-270 hp
2.5" catback~250-300 hp
3.0" catback~300+ hp.
Also, I would strongly recommend a header/dp combo.
Old Dec 3, 2008 | 10:34 AM
PhantomSS's Avatar
hmm i dont know if "stock" can support it. Well it "could" its the EGTs id be worried about.
The stock DP + muffler need to be ditched. They just trap too much heat. I used the regular gmp 2.25 sport exhaust.
Old Dec 3, 2008 | 10:53 AM
Depending on mods it could do 250 and maybe more. I agree that it is not the best route. I said that I strongly/highly recommend a header/dp combo. It all depends on what the goals for the car are.
Old Dec 3, 2008 | 02:11 PM
ReckleSS's Avatar
Appreciate the input. I will look into a header and downpipe and leave the stock catback for now. That is the easiest thing to upgrade, so it can be done any time.
So the stock diameter system is 2.25?
Old Dec 3, 2008 | 02:19 PM
PhantomSS's Avatar
as are the gmp sport and touring exhausts.
Old Dec 3, 2008 | 02:21 PM
mkulrey13's Avatar
gmpp is proven to add +12whp and its a 2.25 so... dont believe anything you read really.
Old Dec 3, 2008 | 05:34 PM
ReckleSS's Avatar
You think it is due to just a differing muffler on the GMPP catback?
Old Dec 3, 2008 | 07:27 PM
BlackSS182's Avatar
i have vibrant header back and injen intake and thats it for engine mods and i picked up probally 15hp you can tell a diffrence with the exhaust and i didnt loose hp i know
Old Dec 11, 2008 | 02:57 AM
ReckleSS's Avatar
Thanks brutha!
Old Dec 11, 2008 | 03:52 AM
Angel's Avatar
Ive done alot of research as right now I have the Pacesetter header w/GMPP catback and stock cat and downpipe which was a huge mistake. I am very paticular about the performance gains and the sound so I have researched almost every available option and what I finally ordered was the Hahn's shorty header, Hahn's downpipe w/highflow cat and the Hahn's catback so everything will be replaced. This system is a 3" catback and it sounds sick and the dyno shows a gain of 17+HP at the wheels. I personally dont think any other system for my 07' SS SC can stand up to this one.
Old Dec 11, 2008 | 10:14 AM
ShortStack's Avatar
Bad move...
3" Should only be used for applications running approx 300hp..
Youve just lost power...
Actually, that pacesetter header is one of the best headers on the market..
Considering you went to a shorty header, you lost gain on the lower rpm band (although it has been placed more up top)
Old Dec 11, 2008 | 10:45 AM
PhantomSS's Avatar
probably sounds like a honda after 3,000 rpm and loud as hell.
delete the GM resonator and replace it with 2 glasspacks. Makes it just a little louder than stock, yet no fartcan sound.
Old Dec 11, 2008 | 10:56 AM
recklessactn's Avatar
MODS listed in sig, I am running the stock cat back exhaust and I made 261 and 228 with a SLP Header and 3" dp w/hf cat
Old Dec 11, 2008 | 11:02 AM
lsjwannabe's Avatar
Diameters? Dp is 2.5" inlet tappers to a 2.0" before cat and back to 2.5" at the end. Stock catback starts at 2.5" goes to 2.25" over the rear axle and back from there.
HP gains with aftermarket catback? Depends on the size most offer between 10~14 hp
Worth it to gut the cat at first? The car will be more raspy but you wont have to worry about it clogging.
Is the catback good enough to support 250whp? You bet
Hope that helps
Old Dec 11, 2008 | 11:15 AM
ShortStack's Avatar
Awesome Wannabe... thats why you gotta love OTT
Old Dec 12, 2008 | 08:38 PM
ReckleSS's Avatar
Thanks wannabe! I have already bought the 2.8" pulley, will add 60# injectors and tune myself using HP Tuners. This will be on stock exhaust from the manifold back and stock intake. Then I will add other components and re-dyno. I am fortunate to have free dyno time and access to HP Tuners, so I will do my best to provide good feedback when I do mods with actual dyno numbers.
Old Dec 13, 2008 | 12:14 AM
lsjwannabe's Avatar
Nice, let me know how it goes and when your ready for 60's let me know
Old Dec 13, 2008 | 06:11 AM
ReckleSS's Avatar
Will do....sent you a PM.....used to live in Macomb County
Old Jun 4, 2009 | 08:55 AM
Staged07SS's Avatar
Administrator
Administrator
the stock lsj downpipe is 2.75" o.d. .... There is a 2" transition that is only about 1.5" long inside the flex coupler, and then it opens up to 2.75". After the cat right before the flange that connects to the resonator, it necks down to 2.50" for about 2". I know these dimensions to be true, because I just measured my downpipe last night when I was uninstalling my shitty ass CTI 3" downpipe.
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
dieGone
Oct 1, 2015 06:27 PM
Sep 28, 2015 12:51 PM
Sep 27, 2015 08:53 PM
