Need More Data!!!
Old May 21, 2007 | 12:12 AM
chipmonk212121's Avatar
Need More Data!!!
Ok, who else is running similar mods as I am? and what times are you running in the quarter with what 60ft? Thanks in advance!
Old May 21, 2007 | 12:55 AM
Doc's Avatar
Doc
sub 13's
Old May 21, 2007 | 02:59 AM
burntorange's Avatar
All I have is the 2.79" CA pulley on a Stage 2 and I run 13.9's ALL DAY long, and the rest of my car is COMPLETELY factory....I am waiting for more **** to come in the mail now. but I do believe that the greatest thing is driver...I launch @ 2K on a stock clutch and all, so I would try something like that maybe.....
Old May 21, 2007 | 07:34 AM
ya, i had the rest of my stuff including clutch installed sat. then track sunday..... i think i just need more time with my setup practicing to get it right.... figure out my launch where i dont spin like hell lol
Old May 21, 2007 | 09:23 AM
SSdan's Avatar
You had your clutch installed and the next day you went to the track?!?! Ever heard of break in period?!?!
Old May 21, 2007 | 09:25 AM
06blackg85ss's Avatar
goddamn that thing aint lasting long lol.
as for me I went 13.9's @103.xx mph on stock pulley and injectors with an exhaust, mounts, and tune. 13.4 @106 w/ 2.55 pulley and very conservative tune.
Old May 21, 2007 | 08:57 PM
I drove the car about 300 miles before I went to the track... but thanks for assuming things. They only reccommend 300 miles on the break-in period. My clutch was flawless when it was taken out after 25,000 miles..... So my clutch will be fine. My tune is pretty conservative. 11.2-11.6 is what im seeing for AFR with my wideband and about 21* timing with 0 kr.
Old May 21, 2007 | 09:20 PM
Mikey851's Avatar
Your trap speed is 3 mph faster than 06blackG85ss on his stock pulley and you both ran a 13.9. That probably means that you could start easy in 1st and then get on it and run a faster time. Are you spinning really bad off of the line? Are you doing a burnout before you make your pass? Are you deep or shallow staging?
Old May 21, 2007 | 11:51 PM
SSdan's Avatar
Hey, if you followed their break in period recommendation, then by all means good! I just hope it lasts for you.
Old May 22, 2007 | 08:10 AM
My first run i had a decent launch with a 2.29 60ft......but i was shifting at the regular 6500 rpm points instead of about 7000. It was also the first time ive been to the track since i got my new tires and i lost my tire gauge and wasnt sure if i let out enough air in the front. Ive landed a 2.18 60ft before, I just think i need to get more practice with this clutch to get myselfa better launch. I figured the car should be around 13.4-13.5 with this setup. maybe a lil higher since its a conservative tune.
Old May 22, 2007 | 08:14 AM
R33P3R007's Avatar
360 L337 User
buy yourself some drag radials.
Old May 22, 2007 | 10:50 AM
BlackSS/SC's Avatar
dRAG rADIALS FTW!
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
JonyyB
Apr 4, 2007 08:32 PM
