need quick ottp heat exchanger help
okay got front bumper off and all I KNow how it goes and all mounted up and all found pics of others and what not.what im not sure on is if the top hose of the h.e goes to the stock h.e or the pump and the other one goes to the opposite one? so what im asking is where does the top hose from the h.e goes to? and then where does the bottom one goes. does it matter im guessing it does becaue one is in and one goes out right? anyhelp will be apreciated thanks
damn my comp is acting up and wont open that anyone can just tell lme if the top one goes to the pump or stock h.e and then i guess the other one will be to the remaining thing lol
&& this didnt come with no brackets and only 2 bolts
The instructions are for the old cx unit. The new h/e use's two brackets welded on top and two bolts for them
oh like i know i had a cobra h.e on im replacing it with yalls h.e my question is does it matter if the top line of the h.e goes to the pump or stock h.e or it does not matter if i put the top going to the pump and then the bottom one to the stock h.e or vice versa?
okay cool so that means the top one goes to the stock h.e if im reading this right.
okay damn im still lost damn blonde momment. oh well ill just put the bottom one going to the pump and the top one to the stock h.e and see if that works out
n20saturn
09-30-2015 12:26 AM
