Need some experts
Old Aug 8, 2010 | 09:20 PM
rollingboostedss's Avatar
Need some experts
I just got done doing my rebuild and on the fire up I got two codes I tried clearing them they came right back
p0017: The timing was set to what I believe was correct right out of GM's book I checked to make sure that it was connected looked to see if any wires were pinched none I could see buddy told me to do an ohms test to see what it is reading need to search for out put read is. any ideas
p0507: I'm not to sure on this one what to really look for I heard of people just cleaning there throttle body and this fixes it looking for some more input
Old Aug 9, 2010 | 11:07 AM
Old Aug 9, 2010 | 06:53 PM
-Jayson-'s Avatar
why dont you tell us the exact code, most people reading this arent going to have codes memorized...
Old Aug 10, 2010 | 12:17 AM
Area47's Avatar
Rent me! per hour
cam sensor timing is off. this is the p0017. set number 4 at tdc on the compression stroke. remove the cam sensor. line up the mark on the hex and the body of the sensor. stick it back in. if it moves. it will be off again.
Old Aug 10, 2010 | 01:35 PM
thanks for the info. you wouldn't think it would be a bad cam sensor right?
Old Nov 11, 2010 | 01:07 AM
skymike83's Avatar
i having a p0017 code but can you point me to were the sensor is and how to align everything properly.... any pictures would help out alot. im a nubi to the cobalt and to this forum
i also have code p0300 and p0068
any help would be appreciated thank you
Old Nov 11, 2010 | 07:40 AM
Frew's Avatar
I like when my cam position sensor was off, I took eight cranks to start my car and it would shoot a fireball
Tupp
Sep 29, 2015 11:07 PM
Spectral
North Pacific
17
Aug 7, 2015 12:57 PM
RedCavyRS99
Mar 25, 2007 01:58 AM
