Need some help
Old Nov 5, 2010 | 06:33 PM
Red04IonRedline22's Avatar
Need some help
Ok these are the codes that im thowing after i instale the OTTP stae 2 kit.
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
DTC P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage
I have replaced the TB and the MAF and the car was not throwing these codes before the kit was instaled. Any ideas anyone?
Old Nov 5, 2010 | 06:53 PM
1fastSSBalt's Avatar
Who installed your Stg2 kit? I'd contact OTTP to start with see if they can help explain why you have these codes.
Old Nov 5, 2010 | 06:58 PM
instaled it myself had no problems with the last stage kit from them call hem yesterda they wont do anything about it. the car is in limp mode and has been sence the kit was nstaled started the car up and itwent streight into limp mode. ive checked everything im out of options
