Need some help
Need some help
So recently installed a stage 3 kit and had it HP tuned by a reputable tuner. Got everything installed and tuned. Runs great... except at like <1500 rpms. As you can see as my car is idling. it kinda bucks around even at idle, and is just rough in general, and also to note if your lugging it a bit in first or second gear, the bucking, rough idle is very apparent to as the car kinda bucks so its not just idle. Kinda at a loss as to what to do. So far ive cleaned the TB, cleaned the MAF off, and changed the primary 02 sensor as per a reccomendation from my tuner. Any other ideas? or is it just maybe the tune is off? BTW this video is from when my car was just started.. seems to get a bit worse after its hot.
http://youtu.be/nwE2-yFL5vY
Mods if it helps any: ZZP 3" intake, ZZP S3 kit with 2.8, Dual pass, phenolic spacer, HE, etc. (and using the 50s for injectors the s3 now comes with) badmab header, zzp catless dp, custom exhaust
Lol - YouTube
It sounds like it has cams sometimes..
This.. bet money this is it.. Exactly what was wrong with my car and it did the same thing..
Lol - YouTube
Lol - YouTube
