need someone to do this
Old Dec 26, 2007 | 04:00 PM
Area47's Avatar
Rent me! per hour
go out when your car is warm {must be ss/sc} pull your oil cap off and feel the air that comes out of it. also, pull your dip stick and check the air volume comming out of there as well.
curiousity is getting to me. i may or may not let you know why i need to know.
thanks!
Old Dec 26, 2007 | 04:02 PM
Raven SS's Avatar
u cant ask for help and not tell why....thinking u have some leakage?
Old Dec 26, 2007 | 04:03 PM
Area47's Avatar
Rent me! per hour
sure i can. thats what i do!
Old Dec 26, 2007 | 04:04 PM
Co|3aLt $$'s Avatar
.... he's a cobalt ninja.
RaineMan's Avatar
you should get some air out... a internal combustion engine is just a big air pump.
Old Dec 26, 2007 | 04:10 PM
quadracer0387's Avatar
if your worried about presure build up, the line that goes from your valve cover to your intake is suppose to delete that
i dont notice anything coming out on mine or dipstick
Last edited by quadracer0387; Dec 26, 2007 at 04:10 PM. Reason: Automerged Doublepost
Area47's Avatar
Rent me! per hour
all im looking for is someone else to measure it in a sense. i know what is acceptable and what's not. it's a simple request.
Old Dec 26, 2007 | 04:12 PM
Bika's Avatar
Fail Less.
i got yer back, Area. i'll do this in a bit. havent driven my car in days/weeks so im due to fire it up.
Old Dec 26, 2007 | 04:13 PM
i didnt notice anything in mine... i assume thats good
Old Dec 26, 2007 | 04:17 PM
redlineblueline's Avatar
is it bad if air is coming out of either
Old Dec 26, 2007 | 04:18 PM
Area47's Avatar
Rent me! per hour
depends on who you ask. got some?
Old Dec 26, 2007 | 04:20 PM
well the last time i did an oil change i was a tad low so i finished a bottle i had off into it and it started to spray back out so enough air is moving to blow a bit of oil back out of the oil fill hole...never felt the dipstick but will do today
Old Dec 26, 2007 | 04:28 PM
Formula96's Avatar
also depends on what motor it is, when i worked for the honda dealer, you knew if someone left an oil cap off of a K24 because it made the same sound as an exhaust leak. My 1992 toyota celica would acually blow every single bit of oil out if you left the cap off, but it did have 240,000 thousand miles on it...
Old Dec 26, 2007 | 04:30 PM
Area47's Avatar
Rent me! per hour
im getting a general consesus<sp> actually. nothing fancy
Old Dec 26, 2007 | 04:32 PM
Gory's Avatar
I have a fair amout of air coming out of mine but what you have to realise is that we have a very small crank case volume and the pistons are moving up and down displacing air in the crancase its really not that big of a deal.
Old Dec 26, 2007 | 04:41 PM
Area47's Avatar
Rent me! per hour
oh it can become a huge ordeal if left unchecked.
i was just curious due to my vacuum sitting a bit lower than usual. no biggie.
Old Dec 26, 2007 | 05:47 PM
Novajoe's Avatar
most cars have it. Shouldn't be much. Like someone lightly blowing on your hand in pulses.
Old Dec 26, 2007 | 05:58 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Area really likes that especially from his blow up doll.
Old Dec 26, 2007 | 05:59 PM
Area47's Avatar
Rent me! per hour
if the blow doll blew me. id be at home right now
sadly, she just sits there like she has seen a ghost
Old Dec 26, 2007 | 06:02 PM
I assume that means her eyes & mouth are wide open and she is covered in white jello topping.
Old Dec 26, 2007 | 06:05 PM
poppagun's Avatar
do a leak down on it
i think you can rent them at auto zone
Old Dec 26, 2007 | 06:18 PM
Area47's Avatar
Rent me! per hour
the vacuum side of the gauge would show something abnormal is the motor farted
Old Dec 26, 2007 | 09:52 PM
Bika's Avatar
Fail Less.
thats what mine is doing. felt like someone was tapping upwards on my hand very lightly. it was also blowing a lil oil vapor on my hand. my vacuum at idle is 19in/hg
nothing was coming out of the dipstick, which is good b/c that would probly denote fucked piston rings.
