Need Technical Help With Cel
Old Oct 30, 2007 | 10:07 PM
streetrcer909's Avatar
Exclamation Need Technical Help With Cel
Hey i had a CEL and was on my way to dealership to have it scanned when light shut off i went to autozone tonite and had them do a diagnostics scan and they came up with a code saying "SYSTEM TO LEAN BANK ONE" does anyone know what this means and is it bad? car is running fine now and light is not on i would like to know what it means and if it is something bad for my car thanks
Old Oct 30, 2007 | 10:10 PM
XM15's Avatar
Its probably from your intake. I've heard that the SS runs pretty rich to begin with, so you're probably alright.
Old Oct 30, 2007 | 10:12 PM
alrite but car should be alrite? i just dont want to have to worry about any technical problems with the car down the road
Old Oct 30, 2007 | 10:13 PM
Cdub901's Avatar
I had somthen like that a fuel mixture to lean but I installed a injen intake and found some water sitting in the little MAF sencer I dried it out and havnt seen the light since.
Old Oct 30, 2007 | 10:16 PM
XM15's Avatar
I can't say for sure long term. I throw the code frequently, but because I'm not f/i its not as big of an issue as you guys. That being said, I don't think you have much to worry about just with the CAI.
Old Oct 30, 2007 | 10:18 PM
flathead0's Avatar
if you have an aftermarket intake it happens i would disconnect the battery for 30 min. or so to reset the computer.
Old Oct 30, 2007 | 10:20 PM
alrite i talked to a friend and he said its just gonna happen when i drive in boost a lot in the car cuz of all the air being sucked in it screws with the sensor or something like that. and when i was driving out of boost light went away
Old Oct 30, 2007 | 10:23 PM
Frankruffolo257's Avatar
its a common problem, try cleaning the MAF and air filter, a buddy of mine had an injen intake and switched the injen filter with a k and n dry flow filter and the light hasnt come back yet. ( 4 weeks now)
Old Oct 30, 2007 | 10:29 PM
even though the lights off i should sitll do that?
Old Oct 30, 2007 | 10:30 PM
wont hurt, go to your local parts house and get some electric parts cleaner, dont just use brake clean, and remove your MAF and give it a spraydown.
Old Oct 30, 2007 | 10:32 PM
alrite thanks man if i could rep ya i would thanks
no problem, as far as the filter, the autozone here had a k&n filter instock, it was a universal one and fit real good.
Old Oct 30, 2007 | 10:41 PM
stealthy1ss's Avatar
Actually you are meaning to say AEM Dryflow. Advanced Auto Parts carry them and I don't know if it is a 3" or a 3 1/4" filter that you need. Measure the old filter to find out.
Old Oct 30, 2007 | 10:52 PM
thanks tyler, you are the wind beneath my wings! hahahaha
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
