Need Valves...Thoughts? Options?
Old Jul 7, 2010 | 04:02 PM
05vue-redline-06ion's Avatar
Ok, so I just got a fone call telling me that I have a few bent valves in my head.
An entire set of stock valves is $632 from GMPD...OUCH!
Supertech valves from OTTP are $340.
What do I do?
Anybody using the ST's?
Old Jul 7, 2010 | 04:06 PM
ItalianJoe1's Avatar
Used stockers maybe?
Nothing wrong with supertech, but the stock valves are pretty high quality stuff.
Old Jul 7, 2010 | 04:08 PM
Yeah I do kno that the Stocks are Sodium filled, but my think is that i want to replace the whole set and Im not foseeing to pay $600+ for some dang valves!
Old Jul 7, 2010 | 04:11 PM
Area47's Avatar
Rent me! per hour
or buy my complete stock head with supertechs.
TurboTechRacing's Avatar
Check out www.TurboTechRacing.com
We have a complete set of ecotec stainless steel valves for a bit of $200 Best prices...
Old Jul 7, 2010 | 04:12 PM
For $200?
Old Jul 7, 2010 | 04:17 PM
Here you go:
http://www.turbotechracing.com/produ...7&idcategory=0
Sold them since 2003 with the cavalier/sunfire ecotec, 100's of sets sold. Direct fitment (OEM size or 1MM over)
Area47's Avatar
Rent me! per hour
not even close
Old Jul 7, 2010 | 04:18 PM
Area47's Avatar
Rent me! per hour
id prefer to run oem or better. not some off the shelf hack job when it comes to internal parts. hell. parts in general.
Old Jul 7, 2010 | 04:19 PM
We do not make these in house, they are made by a large valve manufacture. machined specs are equal or better than OEM.
As stated we have sold them for years, as long as the ecotec has been out in the states, and never one issue of any kind. Price is lower as we went right to the manufacture.
Old Jul 7, 2010 | 04:21 PM
Area47's Avatar
Rent me! per hour
the saying goes.
"buy cheap parts. get cheap results"
sodium filled exhaust?
inconel intake?
hmmmm?
Old Jul 7, 2010 | 04:24 PM
ls1fbody's Avatar
Haz l33t wheelz.
Buy the stoughs of legend.
Area47 is god.
Old Jul 7, 2010 | 04:27 PM
rollingboostedss's Avatar
the saying goes.
inconel intake?
hmmmm?
I hear were you are coming from I just bought these same valves "Im on a budget" and I need to get my car back up and running and with my past history with breaking my car I will be a strong tester for these because I plan on hitting them with some Nitrous
Old Jul 7, 2010 | 04:34 PM
Area47's Avatar
Rent me! per hour
make the egts scream to 1800 degree's. then come back with the answer.
Old Jul 7, 2010 | 04:38 PM
Doesnt sound like a good one....
Old Jul 7, 2010 | 04:50 PM
I don't think it will be close to anything like that... but Like I said I am not disagreeing with you at all if I had the money I would have gotten a better set. but like I said I drive my car hard and I like to push it to its limits "wife doesn't like it" but that is how I am if they don't last I will let you know
Old Jul 7, 2010 | 05:18 PM
Area47's Avatar
Rent me! per hour
a stage 2 car will push 1800 degrees in a mid 4th gear pull.
Old Jul 7, 2010 | 05:26 PM
wow......thats hot!
Old Jul 7, 2010 | 11:32 PM
ralliartist's Avatar
I went with oversized ferreas recently. +1mm. Really not that expensive for the flow gain and the insurance I'll get with them.
Old Jul 9, 2010 | 07:14 AM
We have the Super Tech Valves for $299.99:
http://www.turbotechracing.com/produ...8&idcategory=0
Super Tech Spring set for only $329.99
http://www.turbotechracing.com/produ...idproduct=5197
Old Jul 9, 2010 | 07:18 AM
05Slowline's Avatar
lulz
Old Jul 9, 2010 | 07:28 AM
HunterKiller89's Avatar
stick with GM?
http://www.allecotec.com/product_inf...roducts_id=120
little head work is needed to make them fit since they're slightly larger than stock
Old Jul 13, 2010 | 03:35 PM
Originally Posted by HunterKiller89
stick with GM?
Doesnt look like there is any difference between those and the supertech ones....and the supertech ones are $50 cheaper
Old Jul 13, 2010 | 05:04 PM
im not seeing the valves on ZZP's site. Only the springs and lash adjusters
Old Jul 13, 2010 | 05:39 PM
csementuh's Avatar
They use inconel in high end weapons suppressors and compensators and it holds up very nice to those high temps, so I'd say it should work pretty good in valves.
