need to vent crank case pressure !!
Old Jan 31, 2012 | 11:49 AM
zrated89's Avatar
What's up guys. Last year when i went 12.1 I noticed on one run the dipstick came up a little bit. I'm getting ready to put the car on e85 and a 2.6 and before i do that I'd like to do a breather setup to relieve some crank case pressure. I'm going to do a catch can but seen a lot of turbo lsjs with the cap vented and such. I did a quick search but didn't come up with much. Any ideas or links to buy these parts from? Thanks in advance I would like to do this before running 11s on the 25th
Old Jan 31, 2012 | 11:52 AM
Staged07SS's Avatar
Administrator
Administrator
I think a lot of guys such as Area47 & Wicked used a vented oil fill cap breather setup (at one time or another) to alleviate additional crank case pressure.
Old Jan 31, 2012 | 12:07 PM
zrated89's Avatar
Yea that's what ill go with for now and a better setup later on. Guess ill just tap the cap and grab a cheap filter at autozone or something
Old Jan 31, 2012 | 12:09 PM
Staged07SS's Avatar
Administrator
Administrator
I think either summit or jeggs sells the exact one show in the photo above.
Check them out to.
Old Jan 31, 2012 | 12:13 PM
zrated89's Avatar
Yea I will thanks I also have a spare cap as well from the shop that came off a motor job i did
Old Jan 31, 2012 | 12:24 PM
Pyros777's Avatar
You could use one of these:
Valve Cover Adapter, AN Valve Cover Adapters: Metco Motorsports
Screws in where your oil cap goes. Attach a line to it and T it into the crankcase recirc line found on the back of the engine. After that is in place you should add a catch can into the mix to keep things clean.
FYI a breather filter will just get oil soaked after a while, but its not bad as a temp solution.
Old Jan 31, 2012 | 12:37 PM
newt's Avatar
Exhaust EVAC, have it on my car and it works great. Despite what people say about it not working, the hose would suction to my hand just at idle.
Plus crankcase vaccuum nets a bit more power.
Just a thought.
Old Jan 31, 2012 | 01:05 PM
Leafydialupking's Avatar
I just made one of those instead with a barb fitting jb welded into a 7 dollar autozone oil cap. It did something but not a ton. If you really want to get the pressure out this thread has a lot of good info, Additional PCV Ventilation
Old Jan 31, 2012 | 01:08 PM
freakta's Avatar
Interesting I have mine vented to air and it gets dirty quick
Old Jan 31, 2012 | 01:15 PM
i did notice that when I switch from vented to air to having it tied into my catch can system that it did make my idle better, but I had attributed that to the fact that having the filter on it gave me a huge vac leak and If I closed off my catch can to vac port line that my idle got better as well.
Old Jan 31, 2012 | 01:24 PM
zrated89's Avatar
Yea this is more of a temp solution for now when I'm running on the strip. I don't run around on 24lbs of boost all the time
Old Jan 31, 2012 | 01:27 PM
klloyd's Avatar
I have my cap vented with a K&N mini filter on it. It's been like that for about a year now, haven't had to clean the filter since it's still pink and no more dipstick popping out.
Old Jan 31, 2012 | 01:49 PM
zfissette's Avatar
be very careful hooking the crankcase to full time vacuum, the oil fog is easily sucked out which hurts internal lubrication and will drain the crankcase fairly quickly. had a friend with a civic who ran a vac line from his valve cover to behind the tb, he was going through a half quart of oil a day and eventually span a bearing.
Old Jan 31, 2012 | 01:51 PM
I seem to go through less oil with the valve cover port and the oil cap port going to constant vac than I did with a filter in one. There seems to be the same amount in my catch can but much less disappears though other places.
Old Jan 31, 2012 | 02:29 PM
zrated89's Avatar
I'm just gona put the vented cap on while running at the strip
Old Jan 31, 2012 | 02:32 PM
zrated89's Avatar
Out of all the runs I've done its only happened once and barely came up.
Old Jan 31, 2012 | 03:46 PM
ebristol's Avatar
I have one of ^^^ but have been looking into this idea.
Just a thought.
Moroso 97800 Check Valve
Moroso 97800 - Moroso Replacement Check Valves - Overview - SummitRacing.com
Moroso 97810 Weld in fitting.
Moroso 97810 - Moroso Replacement Weld-In Nipple Fittings - Overview - SummitRacing.com
But I want to run it in the extra O2 bung installed in my ZZP cat-d dp.
It would be the bung after the cat.
Do you think i would be able to produce enough vacuum to pull the valve cover gases out without using the weld in fitting?
Old Jan 31, 2012 | 05:16 PM
mrbelvedere's Avatar
Old Jan 31, 2012 | 05:18 PM
zrated89's Avatar
need to do that but i am lazy
Old Jan 31, 2012 | 05:21 PM
more then likley he dident use the baffled portion of the valve cover if you use the baffeled portion that wont happen
Old Jan 31, 2012 | 05:24 PM
you should plug the pcv port in the head if you are running an atmosphere vent so your not pulling outside air and creating a lean condition and crank windage can pop the distick also
Old Jan 31, 2012 | 05:26 PM
no you wont get the moroso kit it also has the 1 way check valve you need so you wont get exhaust gasses in the engine
Old Feb 1, 2012 | 09:39 AM
zrated89's Avatar
With the ZZP intake spacer iirc its already blocked off
Old Feb 1, 2012 | 09:46 AM
BLAZIN07SS's Avatar
I'm too JDM for you
Old Feb 1, 2012 | 09:54 AM
nope the hole is there for it alteast on mine it was
