new clutch.. shifting?
I installed the stage 2 ky clutch this past weekend with throwout bearing and reused the flywheel because it was all square and didnt appear to have any burn spots or cracks. When removing the trans I accidentally bumped the shift lever forward that the white line runs to. Im finishing the install on Wednesday but am worried my shifts are going to be off, if so what can I do to get the shift lever back into place?
I know its beforehand and hasn't happened yet so I dont know if it will but I would like to have a solution for the problem if it pops up. Thanks
hahahaha i half ass **** but i atleast made sure i used the wire wheel with the electric drill on the flywheel before i put it back together. you should have just left grease all over the flywheel too.
The Rookie24
Sep 20, 2015 04:33 PM
