New to cooling mods. Few ?ions.
Old Aug 23, 2010 | 11:33 PM
Bluelightning's Avatar
Got Bewst?
Originally Posted by 06arrivalSC
Yea lol i want a front mount to get them iat2s down while crusing lol and yup anything more than 25 or 26* timing doesnt really yield any benefits
To answer your other question, my iat2s are around 155*-160* after a pull, and that was after plenty of daily driving/crusing for over a half hour lol so thats pretty accurate for the average pull for me in the hotter part of the day here
Sounds like you need to run more meth. Devilsown says If you're over 150* to put in a bigger nozzle.
Old Aug 23, 2010 | 11:47 PM
Render2009's Avatar
i may be a complete ******* but whats iat2s? the coolent temp or is it your intake temp and how do u read it do u have to get a wideband?
Old Aug 23, 2010 | 11:48 PM
Joemaster70's Avatar
does heatsoak damage the engine or just give u less power
Old Aug 24, 2010 | 03:55 AM
06arrivalSC's Avatar
Hmmm...well what size nozzle are you running on your setup?
iat2s are post intercooler intake temps im pretty sure is the "technical" definition of it, wideband displays your air to fuel ratio, to read your iat2s you need an aeroforce interceptor scan gauge
heatsoak basically makes everything run hotter, it will rob you of power and can cause your car to start pulling timing to protect your engine, but either way, when your iat2s are high you dont want to keep doing pulls and/or beat on your car when your iat2s get hot, cooling mods help to prevent heatsoak and keep iat2s down so your not loosing power, it wont start pulling timing, and its much better for your motor when your temps/iat2s are cooler
Old Aug 24, 2010 | 07:29 AM
Rydis's Avatar
WOW lol. Ya thats the joys of the cooling mods you have right now. Drops temps super fast. With those kind of temps you would be smiling ear to ear with meth lol. What are you're temps after a pull?
i've never used it at the track (still need a good driver launch/shift mod), but doing a 2nd gear to 80 on the free way WOT puts me at about 130..still around crusing temps.
I might get meth one day..but right now..not really beneficial to me as its not a track car but a DD. Still want a header/downpipe and wideband+ custom tune before I even think of going meth anyway.
But yeah..its a pretty clear consensus that our cars loves meth
Old Aug 24, 2010 | 08:00 AM
Staged07SS's Avatar
Administrator
Administrator
With the mods & cooling mods in my sig my IAT2's go no higher than 20*F above ambient while cruising (on a hot day), and no higher than 135*F (on a hot day) during a long pull. Your temps will vary from mine due to location, elevation, mods etc, so only use my numbers as an idea of what to expect.
I highly suggest at least a heat exchanger for your current mods. OTTP is coming out with a gen 5 heat exchanger which is made by Griffin (the same company that made the h.e. for the time attack cobalt & our stock h.e.), and will be the best one on the market. It will be a direct replacement for the stock heat exchanger, and there will be no need for a front mount heat exchanger.
If you dont want to spend the big bucks. Look into OTTP's gen 4 heat exchanger, or ZZP's S3 heat exchanger. Also, it will be a good idea to pick up a dual pass endplate, and an Opt. B kit.
Old Aug 24, 2010 | 10:57 AM
Got Bewst?
I'm running a 7 nozzle
Old Aug 24, 2010 | 02:41 PM
Im running a 5gph right now, what is your setup? pulley, injectors, etc
dennis69
Oct 20, 2015 04:49 PM
Adecker
Sep 28, 2015 10:57 AM
dieGone
Sep 23, 2015 10:20 AM
