New ECU Questions
Old Oct 29, 2008 | 03:23 PM
ikeryder13's Avatar
Question New ECU Questions
If i were to get a backup ECU to do tuning and if i were to have any problems and switch to my stock ECU could the dealer notice?
Old Oct 29, 2008 | 03:31 PM
stangthang's Avatar
I planned on doing the same thing....put my custom tune on the other ECU...keep my stock stage 2 tune on the oringinal ECU....will this work to keep warranty intact?? Does not seem to be much interest in used PCM's for sale....??
Old Oct 29, 2008 | 03:47 PM
ikeryder13's Avatar
i agree bro
bump for more info
Last edited by ikeryder13; Oct 29, 2008 at 03:47 PM. Reason: Automerged Doublepost
Old Oct 30, 2008 | 03:44 AM
ikeryder13's Avatar
bump?
Old Oct 30, 2008 | 01:55 PM
ikeryder13's Avatar
Old Oct 30, 2008 | 02:19 PM
stangthang's Avatar
I have a couple extra ones sitting around... I paid over $100 each and some shipping. Might find one around that price range. I see them every now and then. Sometimes the owner wants 2 or 3 hundred though because it has a crappy canned tune on it that I would never use, maybe for a 2.6 pulley or something....
Old Oct 30, 2008 | 03:16 PM
ikeryder13's Avatar
but can a dealer notice if i swap back the stock ecu?
bump?
Last edited by ikeryder13; Oct 30, 2008 at 03:16 PM. Reason: Automerged Doublepost
Old Oct 30, 2008 | 03:21 PM
rnjmur's Avatar
I don't know for sure if they could tell or not. If the ECU detects a difference in odometer readings then I would say yes, they will be able to tell. Don't know if the ECU will set any code or anything for this though.
Old Oct 30, 2008 | 03:23 PM
ikeryder13's Avatar
yeah i just dont want a sensor setting off because i remove and replace it...
Old Oct 30, 2008 | 03:27 PM
camarokiller's Avatar
You would need to do a crank sensor relearn on the new PCM. Which requires a dealer, or a shop with Tech II
Old Oct 30, 2008 | 03:57 PM
ikeryder13's Avatar
i wanna do some tuining but i dont want it to void my warranty
Old Nov 2, 2008 | 02:39 AM
stangthang's Avatar
can this be done with HP Tuners??
Old Nov 4, 2008 | 12:28 PM
ikeryder13's Avatar
yes can it?
Old Nov 4, 2008 | 12:53 PM
rnjmur's Avatar
HPTuners can do CASE relearn...
HOWEVER....
For ECT (drive by wire) cars like the cobalt, the function currently does not work. So, you will have to use a tech II to get the relearn done.
Old Nov 4, 2008 | 01:00 PM
ShortStack's Avatar
do you NEED to do it.. or will it just throw a code?
Old Nov 4, 2008 | 01:03 PM
ikeryder13's Avatar
is the dealer the only one with tech 2?
Old Nov 4, 2008 | 01:04 PM
rukkee's Avatar
As far as GM's instructions for a pcm replacement is concerned it is required to do a case relearn.
Old Nov 4, 2008 | 02:33 PM
LopsidedJester's Avatar
i tried using another PCM and was not able to do a case relearn with the HPtuners, i believe i still have mine for sale.
Old Nov 4, 2008 | 03:08 PM
rnjmur's Avatar
You can buy them... they are a bit pricey though....
http://www.autorepairmanuals.biz/sit...roduct/OTC3646
I'm sure there are other repair shops that have them as well, you can try calling around.
Old Nov 4, 2008 | 04:05 PM
Sizzle06's Avatar
Does anybody know why i didn't have to do a relearn with my zzp pcm?
Old Nov 4, 2008 | 04:08 PM
ikeryder13's Avatar
see thats what i mean! if i buy another pcm from somewhere else and tune it then its ok?
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
